So, as a result of my complaint, when the cam timing is re-checked by the company that did it, the marks should line up exactly? And if they don't, there is sufficient adjustment in the taper to ensure they do?
(The performance curve has clearly been moved upwards, and the fuel economy in cruise is also clearly worse than it was previously - have now done a lot more kilometres.)
