Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Opinions wanted Mk1 TD
    Apr 2006
    Melbourne, Victoria
    Should I spend the next few days swapping a 1.6TD from my project car into my daily driver?
    Daily driver is currently a very reliable 1.5D.
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Gosford Central Coast NSW
    only if you have all the bits
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Apr 2006
    Melbourne, Victoria
    I've got a complete running 1.6TD in a car in the shed. Its unregistered and likely to be for some time. I would like the driveability and economy of the TD motor in the daily. It just means that i will have two demotored red GLDs......
    Apr 2006
    Melbourne, Victoria
    Daily also has cabrio swaybars, bilstiens with king springs, cordoba drums/booster, audi 100 calipers and a chrome golf ball gear knob.
    sounds like fun then!
    '99 A4 Quattro 1.8T
    Jun 2008
    Melbourne Aspendale
    Im currently nuts deep in the same conversion. I got to drive the 1.6td while is was still in a passat and it felt like it had good power. it was definately more powerful than my 1.5 with the Governor mod... and if felt like it has more power to give up as it was choking higher up in the revs like my 1.5 use to.
    It should be a pretty quick turn around as you have everything. Mine is taking me for ages as the engine mount on the passat is different and incorporated the pump bracket... so i had to pull the pump completely off and change the engine mount as well... I cant wait to get up running again...
    Lots of Deiselers in Oz would kill for that engine in am mk1... No use just leaving it on the shelf.
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    1956 Desoto Panel Van... Maybe to comeback to life as a diesel???
    Jun 2006
    Orange NSW
    Do it! Then tell the rest of us how to. Haha.
    Quote Originally Posted by JustMark View Post
    Way cool, mate!
    What's this governor mod?
    Nov 2010
    yeah agreed, theres no real reason not to do it. Change it and post up the pics
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
    The VE pump has a complex governor system, that varies with engine rpm. There is a flyweight mechanism in the pump top that works against the throttle linkage (which is a spring) to decrease fuelling with increasing pump speed. If you stiffen the spring between the throttle input lever and the governor mechanism, you increase the fuelling over the entire rev range (and increase the rev limit).
    That is the governor mod, in short.
    '99 A4 Quattro 1.8T
    Apr 2006
    Melbourne, Victoria
    Engine is out
    This motor has a k24 turbo, which is big. I will probably swap it for a k14 as I have a couple of these spare.
    I noticed when removing the drive shafts that if I turn one flange, the other turns in the same direction. I can get the other flange to turn in the opposite direction only if i put it in gear (and theres a bit of friction to overcome). Does this indicate that there is an LSD in there or just that the spider gears are stuck? I will replace the flange seals as they are leaking so I might be able to tell from that..... Gearbox code is 8A
