Actually they don't. The fact that the oil light comes on when 700mL-1L of oil has been consumed means that they are fearful of letting sillies who never check anything drive it to death. A light with a chime to scare them "early," if you will is a failsafe.Originally Posted by gerhard
Yes, they do. Also, see above.Originally Posted by gerhard
Right back at you.Originally Posted by gerhard
The manual doesn't say anything about the oil being low when the light is on. In fact, it doesn't mention the amber light that came on in my car. It only mentions a red one, which is an oil pressure warning light. When it came on, I pulled over straight away, turned the car off and pulled out the manual. After finding nothing useful in it, I called VW assist, who told me about the 1L thing.Originally Posted by gerhard
The oil light in the Polo (the first amber one) is actually ultra conservative. Normal driving with it on won't do any damage to the engine, after doing some research, its a "stage 1," of warnings for the obtuse as you say (the red oil light with constant chime is the bad one). And no, unless Woolworths sells 5W30 full synthetic, I didn't use that. Though thankyou for assuming that I don't know what oil to put into my car and/or how to put it in.Originally Posted by gerhard
Are you implying that I've been unkind/abusive to it up until this point? Interesting.Originally Posted by gerhard
Not the same. VW puts the service intervals at 15,000km. The manual tells you how to check/refill/top up the oil and advises it is a good idea. Not at any point does it tell you it will be required of you to do so prior to your 15,000km service interval. It also speaks of not being required for long-life service interval cars and a different short-life (7500km) interval car. Its not clear or concise about the issue. If I could be arsed to get it out of the car now...Originally Posted by golfworx
