Hi,
It could be a water pump. It seems to be common fault in R5 engine. Especialy the earlier, up to 2005.
Happened today driving along,"message" "alarm", "stop", "check coolant level",
stopped the T5 Transporter 68k km, checked the expansion tank, still halffull, but noticed a bit of an oil slick on the coolant, but no water in the oil,Can anyone tell me if it is bad news ie a stuffed head gasket or something "cheaper"
No loss of coolant but the onboard controller keeps screaming
Armdlo
Touareg V6TDi,2008 Silver Leaf, Anthracite, Spare wheel carrier,Air suspension,Factory Tow, Sunroof. 2005 T5 Transporter 4Motion black twincab, grey vinyl roof.Best looking Ive seen.
Hi,
You do realize that those messages really do mean STOP, switch your engine off and don't drive another mm don't you ?
It is your van's way of telling you something catastrophic may be about to happen to your engine.
My money is on an internal leak in the oil cooler allowing oil to force its way into the coolant systemAt least that's what happened to my late Oct 2006 build R5. My coolant bottle was all black inside from the engine oil.
Another possible cause could be failed seals in the water(coolant) pump, but this usually ends up letting coolant into the oil.
I don't know whether it is "cheaper" or not, as VW picked up the tab (under warranty), but given the time spent and the amount of coolant expended on mine I think it would have been cheaper to replace half the engine.
The VWA recommended procedure to remove all the oil from the coolant is very, very ineffective ! Mine has been back 4 times, and still has some in it after the 4th "fix".
It seems VW's rules say to drain the coolant, flush it once or twice (with new coolant), then drive it for 20 minutes. This just doesn't get all the oil out. I seemed to need to drive it for at least an hour of vigorous highway driving to even start to move some of the oil. After nearly 1,000Km of wasted driving I did seem to have gotten most of it out of the engine.
I was told that mine had "the most oil they had ever seen in the engine's coolant". The most worrying thing about that statement is that it implies my dealer alone has seen enough T5s with oil in the coolant to have a good idea of what should be an "average" amount of oil in the coolant !!!!
There didn't seem to be any coolant in the engine oil, but I had the oil changed anyway, just to be on the safe side.
I've just returned from a quickish drive from Canberra to Adelaide and return, and there doesn't seem to be any extra oil in the coolant, so it might be safe to get the "final" flush/clean done now.
At least this trip my van did every last Km on its own wheels (the last two interstate trips I tried it got taken back to the dealer on a flat-top truck because of the oil in the coolant !).
On a happier note, the extra flogging I gave it (to build up heat and help get rid of the oil in the coolant) seems to have made it run a bit smoother and accelerate quicker too (now got 20,000Km up in 13 months, mainly highway work).![]()
Last edited by gregozedobe; 07-07-2008 at 11:52 PM. Reason: Fix error in build date
Hi, Gregozedobe
How many Transporters did you have in past.
Driving T5 myself I also had a couple of problems with mine and your write up makes me thinking, that I should keep my 2005 model as long as practical and buy T6 in the third year of production, no sooner or better still replace it with Toyota van, if T6 reliability would be the same as T5.
I hope you have no more problems with yours.
This is my first Transporter. I've had a few minor problems prior to this (eg faulty door locking actuators), but this was the first time it "failed to proceed". I also hope that I have no more major dramas with it. I intend to buy the VWA extended warranty so I am covered for 5 years.
As far as buying a new T6, I think you are on the right track to let VW make them for a few years before you buy one. It also depends on how many changes they make over the T5, and how well they test them before releasing it to the market. Based on the many problems early T5s had, I think it is safer to assume they don't do a particularly thorough pre-release testing program anymore. So if there are lots of significant changes over the T5 mechanicals and electrics, you could expect more problems.
I would suggest you test drive a HiAce in your chosen environment before deciding whether to buy one. The T5 is so superior for highway cruising (my main use) that I simply could not bring myself to buy one, despite it being a lot cheaper (and almost certainly more reliable).
I do love driving my T5
Also the T6 post by Mogster in this thread may be of interest to you:
http://www.brick-yard.co.uk/forum/fo...020&PN=1&TPN=3
Extended warranty is quite expensive($2300.00 for 2years). I didn't buy one. Instead I save $1,200.00 per year for any possible repairs (if saving is not used for repairs it could be used as a deposit for a new van). I know it doesn't have to be enough to cover for some repairs, but if I would see any symptom of what could be very expensive repair, I can always trade in and let the dealer to take care of it.
I also can't imagine myself driving current Hiace.![]()
My non VWA fix for getting oil out of the cooling system is a 4L container of liquid degreaser from supercheep $9. Put 2L in with water in the cooling system, run the vehicle until the fans kick in, then pull off the bottom radiator hose and make a mess. Wait till it cools and then put a hose in the expansion bottle and the top hose of the radiator and flush vigorously. Repeat with the 2nd 2Ls of degreaser, then drain and flush again and refill with coolant as per manufacturers guidelines.
If there is still more oil coming after that, you have a problem.
Loon's remedy works. I know, I've done it several times...but... some degreasers are quite corrosive, particularly to Al and especially where you have thin components like radiator cores. You have to get EVERY DROP OF IT OUT! This means removing the thermostat and flushing the radiator and block separately. Open drain plugs if you have them and flush...and flush...and flush... If you can, do a pH test of the water in the system after you flush for the last time (before you drop out the water an replace it with coolant). It should be as close to neutral (7) as possible.
Hmmmm....... If VWA extended warranty is that expensive I will have to ponder a bit. Unfortunately it is pretty easy to spend an awful lot in a hurry on repairs.
I wouldn't be relying on an expensive fault being undetectable when the dealer takes it for a test drive before deciding how much to offer you as a trade-in (eg dud turbo, oil in the coolant), but we each have to make our own decisions on how much risk we are willing to tolerate.
