You do realize that those messages really do mean STOP, switch your engine off and don't drive another mm don't you ?
It is your van's way of telling you something catastrophic may be about to happen to your engine.
My money is on an internal leak in the oil cooler allowing oil to force its way into the coolant system
At least that's what happened to my late Oct 2007 build R5. My coolant bottle was all black inside from the engine oil.
Another possible cause could be failed seals in the water(coolant) pump, but this usually ends up letting coolant into the oil.
I don't know whether it is "cheaper" or not, as VW picked up the tab (under warranty), but given the time spent and the amount of coolant expended on mine I think it would have been cheaper to replace half the engine.
The VWA recommended procedure to remove all the oil from the coolant is very, very ineffective ! Mine has been back 4 times, and still has some in it after the 4th "fix".
It seems VW's rules say to drain the coolant, flush it once or twice (with new coolant), then drive it for 20 minutes. This just doesn't get all the oil out. I seemed to need to drive it for at least an hour of vigorous highway driving to even start to move some of the oil. After nearly 1,000Km of wasted driving I did seem to have gotten most of it out of the engine.
I was told that mine had "the most oil they had ever seen in the engine's coolant". The most worrying thing about that statement is that it implies my dealer alone has seen enough T5s with oil in the coolant to have a good idea of what should be an "average" amount of oil in the coolant !!!!
There didn't seem to be any coolant in the engine oil, but I had the oil changed anyway, just to be on the safe side.
I've just returned from a quickish drive from Canberra to Adelaide and return, and there doesn't seem to be any extra oil in the coolant, so it might be safe to get the "final" flush/clean done now.
At least this trip my van did every last Km on its own wheels (the last two interstate trips I tried it got taken back to the dealer on a flat-top truck because of the oil in the coolant !).
On a happier note, the extra flogging I gave it (to build up heat and help get rid of the oil in the coolant) seems to have made it run a bit smoother and accelerate quicker too (now got 20,000Km up in 13 months, mainly highway work).
