Ok. Will the steering wheel have to come off to do that? I took off the plastic covers, and wiggled the contacts, without making any difference.
I also steel-brushed all the contact points atop the battery, inside the terminal shoes, the first negative ground connection below the battery and the connection on the diesel solenoid. They all looked fine, with no rust or crud at all. That didn't make any difference. Edit: The portion of the main ground cable, under the battery, where the ground-connector bites into it, was visibly green from copper-corrosion. I wasn't sure if that mattered any, and guessed it would be cleaner under the biting clamp.
Then I checked the air-intake valve by the EGR-regulator, to see if it was open and could move freely. It moved freely and was in open position. Not much slag in there either.
Then I checked the 109-relay; which seemed to be working fine:
Edit: BTW, I read somewhere on TDI-club, that the ignition-switch must signal the ECU through fuse 29 (not 100% sure about the number), for the ECU to wake up and open ground to 85 on relay 109, so it can close and send more power to ECU. The relay is working, so is there anything else the ignition switch is supposed to do, but not doing already now?
