"Quite normal" in what way?
hey, i had the oil light come up on my car once, i posted on some other forums and was told it is quite normal and that i should be checking it frequently between services. I was worried because it was after a bit of spirited cornering, but its been fine for ages now
07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
Resident grumpy old fart
The car has been doing some regular highway drive since last serviced (~40KM each way)
Anyone know if this is related to the oil consumption?
I' just like to find out the cause, normal or abnormal
06 Polo TDi
