Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Not kicking over when hot
    VIC
    If I persist with cranking, I loose window regs and cruise control. Anyone else?
    Sent from my C6903 using Tapatalk
    -- Drive like a fat girl on Facebook... Get those angles right and know your sweet spots! --
    Dec 2008
    Sydney/Canberra
    Test your battery.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Bowral, NSW
    Quote Originally Posted by lol.u.mad.bro View Post
    That'll be battery
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2014
    Central Vic
    I've had issues with my FG Falcon (traded) which seemed to revolve about battery voltage .....reboot (neg lead off for say 10min) or new higher CCA battery would be the first steps with any BODY, ICE, HVAC etc problems. It costs nothing to try a reboot. (Obviously without key in ignition)
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Sorry for not updating guys.
    Still have not done anything about this, it has not occurred for months now. Maybe trading soon anyway.
    As I previously said would only fire after pushing on accelerator.
    Would be interesting to see what the outcomes of others were.
    Aug 2011
    Lake Macquarie
    I had the same symptoms as yours in my golf and as soon as I replaced the battery the problem was solved.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
    VIC
    Battery
    Apr 2008
    Vic
    I’ve also had an ongoing issue with our 103KW BKD engine Golf.
    It would start instantly every time when cold, but when hot it needed a bit more cranking.
    As the months passed the amount of cranking required when hot increased to the point where it would not start at all, even after numerous attempts.
    It seemed the engine was still being cranked at what I thought was a reasonable speed, although it turns out it was not fast enough.
    As soon as I replaced the battery the problem disappeared.
    I know it still has an issue with the cam angle sensor which will be replaced when the cam belt is done very soon, but I think the cam angle sensor must assist the starting when hot as the combination of a dud cam angle sensor and a battery that’s not so new is definitely a problem.
