Results 1 to 10 of 18
Thread: Not kicking over when hot
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Team.
    Vehicle MY07 Jetta DSG 103kw
    Had a search, have not found what is happening or possibly about to happen.
    Has occurred twice in two weeks,after the car has been running for approx an
    hour,(doesn't seem to occur on shorter trips), when the car has been turned off
    and left for short period say 5-15 minutes ,when then trying to restart the motor it will
    turn over but not fire, you can try a number of times but will just crank over and not fire up ,
    If you push the accelerator down while cranking the motor comes to life.
    Have no display warning symbols at this stage.
    Had a look at a few injector failure threads but they seem to be mainly for the 125kw motor.
    Maybe a sensor somewhere ???
    Thanks All.
    Dec 2009
    Kew, VIC
    May be wear on the camshaft resulting in a marginal fuel supply at idle — if so the failure to fire will gradually become more frequent.
    Pushing the pedal down feeds more fuel, hence it starts.
    (Just guessing, of course.)
    Gosford Central Coast NSW
    More than likely this is a sensor issue, or an injector issue. I would get it scanned as soon as you can. I believe there were some people that reported similar symptoms just before injector failure (caused by the wiring loom fault).
    Camshaft wear was really only a problem for a certain production run of engines, mostly in north America.
    Quite unlikely to be a mechanical fault.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2008
    Sydney/Canberra
    Check battery voltage when cranking, as well as cranking speed. Cranking speed needs to be higher than 280rpm before it'll fire.
    Could also be a starter motor on it's way out.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2007
    Thanks Guys will let you know the outcome shortly.
    Although Umai-Na!! presents some logical options
    '99 A4 Quattro 1.8T
    Mar 2013
    Canberra
    How did you go, I'm in the same boat with my jetta.
    VIC
    Same here. Please let us know what the problem is
    Sent from my C6903 using Tapatalk
    -- Drive like a fat girl on Facebook... Get those angles right and know your sweet spots! --
    Jan 2014
    Western Suburbs, VIC
    I have the same issue with my wifes Audi A3 (05, BKD 103KW)
    It's driving me crazy, have to crank for seconds sometimes. If i abort cranking, and then crank again, it pretty much starts instantly
    Jun 2011
    sydney
    cam sensor
