Sorry - I forgot to mention. Apparently the output flange on the turbo itself is 2.5" - so I'm just going to gut the DPF and get a Revo Stage 2 tune.
otto - where abouts in Sydney are you? You're welcome to have a listen of mine![]()
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
Have you spoken to Revo about that? I looked on their website and it does say the stage 2 tune for CRTDI is designed 'to work with a full DPF bypass exhaust system' which one would assume means without a dpf, but its rather carefully worded.
I will assume to know all the legal implications.![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Its got a bit more freedom above 4000rpm, but i think (THINK) its lost a tiny amount of torque down below. This fits into the theory about large diameter cat back exhausts losing pressure(to put it simply) and consequently losing a little torque in the very low revs .. Ive yet to determine that because the DPF would be the source of a massive restriction up front so i cant quite get my head around it.
If i were to do it again, I would go 2.5" all the way through. But if someone does a DPF bypass in AU, ill just get a 2.5" dump and connect it to the existing 3"
Drivability wise, it revs more freely especially above 3.5k rpm , economy wise ive seen no difference.. still getting 4.9L/100 Average with my mix of commute and short drives around, in the after hours.
If you want noise, just get rid of the pancake muffler at the back and put a straight pipe in. Im not too sure that this mod was worth the money, even though i got it for $250 all up.
If my tune can accomodate this and make a couple more numbers then its all good. I cant really gauge its effectiveness, but Im happy enough how it is. Ill let you know when I get to do another mountain run when I get my new springs
mk6 TDi - DSG -VIEZU tuned- Carbonio . Whiteline RSB/Neuspeed FSB . Golf R interior . Defi boost . Twin 4" Magnaflow tips . GTI shocks & springs
DPF delete is easy, but the only company I would currently trust is Custom Code. Nobody else has spent the time to sort it properly, and LOTS of reports worldwide of regents finding a way to turn back on, it's extremely complex coding. Just so you know it is very illegal and carries a max fine of $8k for an individual and $120k for a company doing so. I am meeting with several parties on this issue in coming weeks as I attempt to make my high flow sports DPF a legal reality, it's a way to go, but without approval it's not something I am going to release.
It will allow a full power delete style tune, but without all the obvious soot, and the massive illegality.
The government is indeed concerned about DPF deletion, just a matter of how they are going to police it, which is very much the plan.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Unfortunately, we can't protect everyone by deleting their comment. Stupidity can be costly if they get caught. Wish them luck.
Watched TV yesterday, they were showing a P plater driving while drunk and filming himself with the camera held between his legs. When he was questioned, he said "he had done nothing wrong."![]()
