Results 11 to 20 of 22
Thread: New diesel
    Adelaide hills, SA
    Quote Originally Posted by Russ59 View Post
    Are we still talking about the car, or women
    The same applies to both.
    Adelaide hills, SA
    Quote Originally Posted by cogdoc View Post
    Scotty, a diesel can't really detonate, no spark plug to fire too soon ( causing detonation). The subie will undoubtably be about the same power, torque at least, in the real world, so I'd leave them alone.
    Any top mount intercooler is a bad idea, ESPECIALLY water, for once it gets hot, well it stays hot for a long long time. Heat rises, so it seems silly to put something you want to keep cool on top of the hot engine, and in a place of lower air pressure. Water 2 air is great for drag racing, but the main reason I gave up on a water intercooler is the heat retaining problem, and virtually every US monster diesel runs air to air because of this.
    Bummer, because I thought I was on a winner!
    Correction.
    Diesel engine will detonate (have pre ignition).
    Unless I learned porkies at the school.
    Detonations in diesel is less noticeable because of its noise characteristic.
    Usually you will notice it when it's too late, (loss of performance due to engine damage, like hole in the piston caused by leaking/faulty injector).
    I'm sure you will find more information on this.
    Water intercooler has also its advantage and Subaru has their reason for useing it.
    http://www.frozenboost.com/stpg.php?...d=water_to_air
    Jun 2008
    South Coast N.S.W.
    For a more detailed explanation of the ignition process comparison between petrol and diesel, I found this which sounds reasonable without being too complex for us non mechanical nerds. http://answers.yahoo.com/question/in...3223725AAqSZ1v
    Russ
    2005 Subaru Outback 3.0 R Premium
    Jan 2008
    Sunshine Coast
    I'd like to know how a CAM driven injection system could ever pre-ignite. Nothing happens until you add the fuel, and as the PD VW's don't have variable cam timing, the start of injection is mechanically constant. All the ECU can control is how much diesel is "spilt" back into the fuel runners during injection, hence controlling the amount injected. The injector nozzle itself responds to pressure alone, so unless it's faulty, it would never be able to preignite. Adding propane changes all that though. Here's a great explanation of PD:
    http://en.wikipedia.org/wiki/Unit_Injector
    Water intercooling for petrol is a great thing. For a normal road driven diesel, not so. That site is all about petrol Mr T. Believe me I've looked heavily into it, and have actually bought all but the core when I decided to abandon a W2A idea. It all comes down to how much the car is on boost, which between petrol and diesel is very, very different. W2A in a diesel would be great for several minutes, but once it finally got hot in a almost always boosting diesel, it would then become a heater instead. Water takes longer to heat up, AND to cool down. Defeats the purpose in normal driving. Hey I wish it wasn't so!! As much as it appeals to me, none of the US guys are into water intercooling for road drivers. That says something given the insane budget of some of these people!
    http://www.autospeed.com.au/cms/A_109423/article.html
    It's all a moot point really, I'm sure Subaru have done the testing, and it will be interesting to see, and hear!
    Adelaide hills, SA
    It should be here by the end of this year, that's what the dealer in Adelaide said.
    Jun 2008
    South Coast N.S.W.
    Will be interesting to see what sort of sales the diesels will bring for Subaru. They do have a nice sporty look about them though. Maybe if they sell really well VW might consider bringing the Golf GTD to OZ sooner rather than later
    Russ
    Adelaide hills, SA
    Yeah, it would be nice if they bring the 4motion version as well.
    The thing to go for in the Forester is the longitudinal drive train system as is in Q5.
    Here is another option to Forester:
    You will like that one
    http://www.mediafire.com/file/nndmzf...I_Q5_Eng_Trans[1].pdf
    Jun 2008
    South Coast N.S.W.
    Would be nice, but an Audi is a bit out of my price range atm I'm afraid. Maybe if I win Lotto, but that's highly unlikely I would think
    Russ
    melbourne
    thanks guys for the info- LOTS to learn about cars for me.
    what i dont get is, despite the fact that everyone knows that top mounts see huge temperatures, why do subaru persist with this?
    im reading up on nasioc re top mounts. any other obvious reasons?
    i'd take em on. it'd be interesting- we'd have same power, but i'd have less weight. and the advantage of my car being a cutesy girl's car.
    Last edited by Buller_Scott; 09-04-2009 at 01:11 AM. Reason: i read up on nasioc re top mounts. thanks anyway!
    Jan 2008
    Sunshine Coast
    Subie flat four is a very very wide motor. Think of a BMW motorcycle.
    Leaves little room around the sides like a normal engine, and a whole lot of top room. Guess the figured they'd use the space, and by keeping it close they run short pipes, giving quicker response, when it's cool anyhow!
    How's that for a guess??
