Results 1 to 4 of 4
Thread: In need of help
    In need of help
    Hey guys. I have a vw t5 with caac.
    Im from Melbourne and stuck in Sydney with the van in limp mode.
    I have the Fuel Pressure Sensor code 5244.
    Could anyone help me out with a solution so i can get home??
    If i sent 5 volts to the signal wire would that get me out of limp mode to get home?
    Im clutching at straws everywhere is closed
    Sent from my SM-G930F using Tapatalk
    Albany, WA
    How did you go?? Only just saw this post. Sorry not technical enough to help out.
    Van still broken down. I replaced the fuel rail with the sensor and valve but still no good. But it might be down to an engine speed sensor
    So still havent found the problem with my van.
    It brings up fault codes and when the corresponding sensor is changed it then brings up a different fault code. But the symptoms are always the same with only the glowplug light on the dash and in limp mode.
    So far the fuel pressure sensor, fuel regulator, speed sensor and ecu have been changed. Now its bringing up an inlet manifold sensor.
    The only common fault code seems to be an abs fault.
    Really stumped as to what could be going, any help would be greatly appreciated.
