Results 31 to 38 of 38
Thread: My Provent install on a PD engine.
  1. #31
    Dec 2008
    NSW Sydney
    Quote Originally Posted by cogdoc View Post
    You NEED a high flowing Provent, designed with trucks and the like in mind. And again, the problem is tubing, I have high quality hose that will fit over the Provent fittings, but the hose is HUGE, and too hard to work with in the engine bay, so I actually used the smaller hose I bought to fit the drain. And yes, it's sikaflexed in. Remember it has to handle both oil, and the hot engine bay temps. [/URL]
    Did you try this place http://www.pirtek.com.au/ ?
    They are in 5min drive from my office, I will visit them after I buy Provent.
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
  2. #32
    Jan 2008
    Sunshine Coast
    Let me know how you go. I'm reluctant to sink any more money into the Provent install for now, and have quite a collection of hose and fittings that didn't work already!
  3. #33
    Adelaide hills, SA
    Do you know that you could use the copper tubing to bent the exact shape pipes you need and use only small pieces of the silicon hoses to connect them.
    I think I'm going to plumb it that spare Provent I have in our Golf and I post the pictures when finished.
  4. #34
    Adelaide hills, SA
    The diesel fuel could be used for cleaning that inlet tract.
    We used to use it as the degreaser in the old days.
  5. #35
    Jan 2008
    Sunshine Coast
    Not a half bad idea again...hmmmmmmmmmmmm
    At least it's not that explosive if it goes pearshaped!
  6. #36
    Jan 2020
    Victoria, Australia
    Provent in T5.
    Very easy to install in T5 no elbows needed just use silicon hose which is more flexible than rubber hose.
    The bracket is fixed using existing threaded hole that also holds the added Anderson plug for connecting CTEK battery charger to charge the battery since I do many short trips during the day.
    I know this is an old post but I've been scouring the web trying to find an image of the location for a proven t in a 2.5D T5 and this is the only reference I could find and the images seem to be missing in action.
    Any chance of another link or reposting the pics?
  7. #37
    Adelaide hills, SA
    Quote Originally Posted by bucketeer View Post
    I’ll check in my google drive. But, it’s very easy... on left side, kind of next to the battery and bracket attached to M6 bolt from the top.
  8. #38
    Jan 2020
    Victoria, Australia
    Is that above the ABS control block?My Provent install on a PD engine.-pxl_20210607_084830413-jpg
