Results 11 to 20 of 38
Thread: My Provent install on a PD engine.
    Adelaide hills, SA
    Provent in T5.
    Very easy to install in T5 no elbows needed just use silicon hose which is more flexible than rubber hose.
    The bracket is fixed using existing threaded hole that also holds the added Anderson plug for connecting CTEK battery charger to charge the battery since I do many short trips during the day.
    Jul 2005
    Newcastle, NSW
    So you have a tube running from the bottom of the provent that has a stopper in it? I am reading the items list but unable to see the 12.5mm tube in the pics but see you mentioned it. Are you draining the oil through this pipe, and is it effective?
    Clean install again it must be said.
    Jan 2008
    Sunshine Coast
    Good luck with a "clean install" in the golf engine bay mate....
    Oct 2006
    hey brenton im just curious as to what car u have? PD is mk4 era isnt it?
    nice write up!
    i should get one of these for my Polo!
    where do you get them???
    i need to get one ASAP!
    Adelaide hills, SA
    Quote Originally Posted by mikinoz View Post
    Yes, just 12.5mm clear vinyl tubing forming the loop and long enough to hold a small amount of oil. The other end of tubing is just bend and tied with the plastic
    tie. I check the tube weekly; drain it probably every 3 months. So far I’ve done 65,000km. Top up between 7,500km oil changes is around 1/2Lof oil; I top up
    only when the oil level gets bellow min. mark on the dipstick.
    I believe that changing the engine oil more frequently has positive effect on the amount of the blow-by gas since the clean oil will give a better piston seal
    hence the less of the blow-by gas.
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by peedman View Post
    He has a MK V GT Sport TDI, MK V is still PD,
    MK VI is CR (common rail)
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Adelaide hills, SA
    Quote Originally Posted by GoLfMan View Post
    nice write up!
    I got mine from HSY Imports in Adelaide and they are supplied by Man Hummel in Sydney. I think it is cheaper to go directly.
    Dec 2008
    NSW Sydney
    Quote Originally Posted by cogdoc View Post
    Yep, I have to go and see that filter before committing myself for this job. I wonna see if it can be mounted somewhere in the front near EGR valve... They are in Blacktown, might go there this Saturday morning.
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
    direct eyy
    where would I do that.... blonde question!
