Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Modshack experience & questions.
    Jul 2005
    Newcastle, NSW
    Indeed, it could be - You should clean your egr and at the same time degrease a nd clean your inter cooler of oil and install an oil/air separator in the breather line so you reduce the gunk going through the system.
    Nov 2007
    did you perhaps over oil the air filter? It could have covered the sensor in your MAF? Try getting some MAF cleaner and giving it a clean.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Dec 2009
    Melb. (SE), VIC
    Quote Originally Posted by poyta View Post
    Did not oil the filter that came with the intake. Doesn't appear to be the oiled type.
    Replaced with stock intake for the time being until new parts arrive.
