Nice work. The small line is the turbo solenoid bleed line, and if you block it you will have all sorts of woe, as I did! It dumps the pressure on the negative side of the solenoid which actuates the VNT vanes in the exhaust turbine.
Stuttering is a problem a few have reported, although I have not experienced the same. May be you lot in colder climates just get too much cold air for the MAF to cope with, a problem not so apparent in QLD. Making your own plumbing for the inlet is quite easy, and if you can get the scoop off the front of a Forge unit, would make it a lot simpler, not sure if they would sell you just the scoop. I made my own fiberglass front, but that's a major project to get right, messy too! Sealing the front is a great idea, but makes it even louder outside!
Now you can pull the MAF grid out, and help the airflow a little more!
