Results 1 to 10 of 13
Thread: Modding turbo diesel
    Mar 2009
    Ok guys it has probably already been asked before but wanted to know if anyone has golf tdi that has been modded to the max. I am looking for sleeper but something can take out on track days and would like to get close to the 200kw mark if could can this be done?
    melbourne
    dont be silly.
    get a chip (125ish kw) then work on tyres, brake pads/ rotors, and suspension suspension suspension as well as the bushes...
    power doesnt make you fast, cornering does.
    Adelaide hills, SA
    What he said. But, rather than chip, go for the remap.
    If it's going to be a sleeper, you probably want to drive it as your daily and not as a purpose built for the track days only. Then you better stay within the safe limits; usually +30kW and around 72Nm torque.
    Mar 2009
    Ok yes I do want sleeper but every now and again take out to track for drags want something different out there so want it quick. What would be the best diesel to tune then
    Adelaide hills, SA
    Quote Originally Posted by passat08 View Post
    V6TDI or V8TDI.
    Dec 2008
    Sydney/Canberra
    V10tdi!
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2011
    If you're chasing that sort of power. You will need to go down this path.
    http://www.darksidedevelopments.co.u...0-16v-tdi-bkd/
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
    Mar 2009
    So could u do same in golf? Then as same motor
    Mar 2009
    What about the 110tdi are they any good?
    Gosford Central Coast NSW
    You can definitely make 200kw with any of the 1.9 or 2.0l 4 cylinder TDI's, but you will have to pour money into it (especially if you do not know how to DIY.
    All you need is a really big turbo kit, a set of high flow injectors, a straight through exhaust with no DPF or cat, and a tune to run it all.
    If I had $10,000 to spare it could be done easily (ok, its not the money though, its justifying the expenditure) Basically the upper limit for the 4 cylinder TDIs without going to 2 or more turbo's and on standard internals is 300hp.
    I would get a 9n Polo or a MK5 2.0L TDI (NOT a GT) and buy all the fancy bits from darkside.
    Even if you set your goal a little lower you could have a very quick car that not many will suspect.
    Hell even my humble Octavia surprises some impatient falcadore drivers when freeway merging nowadays, and its only cost me about $2500 in engine mods. (Turbo, exhaust and tune)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
