Results 1 to 10 of 17
Thread: mkv 1.9 tdi golf mods help?
    Jul 2011
    Hey guys, just wanted as much input as i can get from my fellow diesel drivers as to what performance/body mods i should/can get done for my 08 vw golf V 1.9 tdi. Thanks guys!
    08 VW MKV Golf TDI - reflex silver | pioneer nav unit | 18" black Apec racing rims | DSG | custom TurboBack exhaust | reset springs | gti steering wheel | R-Line tail lights | angel eye/projector headlamps | gti front | R32 rear | red engine cover | opticoat |
    Sep 2006
    Search is your friend!
    ECU reflash
    Coilovers/ springs,shocks
    front lip / side skirts
    DPF (spelling) mod
    Air intake?
    Wheels
    tints
    RNS510 (if don't have it)
    Seriously, its all here man just search!
    Quote Originally Posted by adrian13 View Post
    Mine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
    Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
    Dec 2009
    Melb. (SE), VIC
    Ecu reflash is the first thing.
    Quote Originally Posted by Darks RS View Post
    DPF (spelling) mod
    the 1.9 never came with a DPF, which is good! Less problems.
    indeed. Search IS your friend, plenty of info on here, quite a few of us have modded them!
    Dec 2009
    Melb. (SE), VIC
    Wouldn't an 08 be a 2.0l 16v?
    Jul 2011
    Quote Originally Posted by getjet View Post
    well according to the dealership i bought my car from and the logbook, its a 2008 1.9 tdi
    Dec 2009
    Melb. (SE), VIC
    In your service Manuel, there should be a sticker with a whole heap of random letters etc on it. What does it say next to engine / trans?
    If it says BKD then it's the 2.0l 16v.
    Oct 2010
    I think only the Pacific models were the 2.0L
    edit. mm hang on this isn't true. I'm looking at some on Carsales now and there are Comfortlines that are 2.0L and also 1.9L.
    The 2.0L ones have a badge that says so and the 1.9L just say "TDI"
    Golf GT Sport TDI
    Jan 2008
    Sunshine Coast
    Comfort lines came in 1.9, Sportline and up had the option, but most are 2.0. The biggest killer for the 1.9 seems to be intake pipe restriction, EGR restriction, small side mount intercooler from the top of my head, but the 1.9 polo TDI guys will know way more than me.
    Work on the same old hot rod principles, air in, exhaust out, cool the intake air, clean out the sludge from the blow by, run some fuel doctor through it, get a tune, even a basic overseas or local handheld tune will make considerable difference, the Viezu one on my TDI is astounding, but as I flog those now it sounds biased.
    Oct 2010
    Melbourne, VIC
    WEDEL.1 reflashed his 1.9 PD TDi MkV Golf with Oettinger and says it transformed his car so that it performs almost identically to the 103kW 2.0 PD version. The big trailer he towed across SA and WA last year certainly would have tested the engine.
    But as others have said, this engine was also used in the 9N3 Polo and the same tuning applied to these would also work well with your Golf
    My 1.9 PD TDi runs a Viezu remap (1 have three + stock, actually) and it's great. Others have had good results with CustomCode, DNA Tuning and Giac so I would decide on which dealer can locally support you best as well as on pricing.
    Resident grumpy old fart
