FYI in reverse light upgrade.
I found running two of the higher powered bulbs in the reverse light and fog side put too much load on the circuit and began to pulse. Bad news.
I moved the stock bulb to the fog side and ran a wire over. Also you want a diode for coming back, so it doesn't activate the reverse circuit when you put the rear fog on.
