from what i understand about getting it coded out it was just a box they tickd while doing the revo tune. not sure about other tuners but its very possible as revo arent a HUGE name.
how do you spray inlet cleaner guys,
do you take the boost hose off the inlet flap motor and just squirt a bit in?
or do you spray it up the top just after the map at that inlet?
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
Have taken apart the egr/intake flap assembly today to check it. Found it to be much cleaner than expected. I cleaned it wit a bit of wd40 I had handy and an air hose. The intake flap was checked by hand and moves freely from open to close. After reinstalling I checked whether the Intake flap is closing when ignition is turned on. I found it was only moving about 3mm when cycling between on and off.
Can anyone tell me whether this is normal?? When the ignition is set to the on position(but not started) should the flap "completely" close, or only move a little bit like it is doing??
Regards
Simon
It should completely close and remain closed on ignition off, you hear it "buzz" for about 30 seconds post stopping, then it opens back up ready for next start. When idling it should be part open, and open right up with a rev. If it's not shutting that's not a major thing, more if it isn't opening.....still it could be throwing an error and thus the EGR is out, THAT will affect your idle / running....you're going to have to scan this, find a lappie or a buddy with Vag Com locally on here!!!
---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
It's something you ask the tuner to do, I'd expect anyone that has a decent diesel range of tunes would be able to do it, certainly Parso, Custom Code and Viezu can in my experience, no doubt others can too.
I have just given the car a drive and it now idles as it used to(between 820-840rpm). Still not sure about the intake flap though. I was only turning the ignition on/off and not actually starting the car. Can I pull the large main intake pipe from the bottom of the intake flap and start the car without any damage to the engine and check what position it is at when running?
BTW there are no error lights up on the dash. Does this mean their wont be any error codes if checked by a VAGcom or can there still be errors even with no dash light errors shown?
Regards
Simon
From what I have been reading the intake manifold flap motor is there as an anti judder when turning off the engine. It closes upon turn off to kill the oxygen supply and then opens again after 3secs. If it fails in the open position it may just judder a bit upon turn off and has no effect on the running. When turning off the engine there is no noticeable difference in an increase of judder (it is smooth as it was when it was new). I will buy one of these obd2 boxes to read some fault codes though.
Does anyone have any suggestions on what to buy? I like the idea of these bluetooth ones here.
Bluetooth Scanner OBD2 OBD II Diagnostic Interface Scanner Fits Android Torque | eBay
Regards
simon
