Results 1 to 10 of 26
Thread: MK5 TDI Idling high
nissman MK5 TDI Idling high 08-03-2012, 05:38 PM
Transporter Jmac can help you with that... 08-03-2012, 06:28 PM
davidno64 My understanding. This is a... 08-03-2012, 07:02 PM
nissman I thought only the sport... 08-03-2012, 07:45 PM
Transporter You have no DPF in yours. How... 08-03-2012, 07:55 PM
nissman Have done 66000km? 08-03-2012, 07:58 PM
Transporter The first step is to get it... 08-03-2012, 08:05 PM
davidno64 OOPs, you guys are correct.... 08-03-2012, 08:20 PM
nissman Just some extra information.... 08-03-2012, 08:39 PM
Greg Roles Yep, pretty likely. My TDI... 09-03-2012, 10:17 AM
jamie88 i had this problem, scanned... 09-03-2012, 02:25 PM
Greg Roles Caused by EGR/ blowby... 09-03-2012, 02:44 PM
jamie88 the egr and manifold flap... 09-03-2012, 02:52 PM
Greg Roles Ahh coding out the EGR was a... 09-03-2012, 04:12 PM
jamie88 yeah when the tuner asked i... 09-03-2012, 04:23 PM
asa572 Tell me more about getting... 09-03-2012, 04:41 PM
jazd So ****ing over my DPF.... 09-03-2012, 11:15 PM
jamie88 from what i understand about... 10-03-2012, 09:52 AM
nissman Have taken apart the... 10-03-2012, 10:21 AM
Greg Roles It should completely close... 10-03-2012, 12:26 PM
nissman Haven't tried spraying intake... 09-03-2012, 07:09 PM
    Jan 2008
    Sunshine Coast
    Ahh coding out the EGR was a good move. As you dont have a DPF you can get by without a Provent, I'll leave you alone. I am getting Viezu to code down the EGR in any diesel tunes I do.
    Jul 2011
    NEWCASTLE NSW
    yeah when the tuner asked i told him i definitely wanted egr coded out. such a good move. and no dpf, I'm one of the lucky ones ! no further mods needed haha!
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by lowtdi View Post
    Tell me more about getting the EGR coded out please!
    Oct 2010
    So ****ing over my DPF. Bloody light came on again today.
    Golf GT Sport TDI
    Jul 2011
    NEWCASTLE NSW
    from what i understand about getting it coded out it was just a box they tickd while doing the revo tune. not sure about other tuners but its very possible as revo arent a HUGE name.
    how do you spray inlet cleaner guys,
    do you take the boost hose off the inlet flap motor and just squirt a bit in?
    or do you spray it up the top just after the map at that inlet?
    Mar 2012
    Brisbane, Qld
    Have taken apart the egr/intake flap assembly today to check it. Found it to be much cleaner than expected. I cleaned it wit a bit of wd40 I had handy and an air hose. The intake flap was checked by hand and moves freely from open to close. After reinstalling I checked whether the Intake flap is closing when ignition is turned on. I found it was only moving about 3mm when cycling between on and off.
    Can anyone tell me whether this is normal?? When the ignition is set to the on position(but not started) should the flap "completely" close, or only move a little bit like it is doing??
    Regards
    Simon
    Jan 2008
    Sunshine Coast
    It should completely close and remain closed on ignition off, you hear it "buzz" for about 30 seconds post stopping, then it opens back up ready for next start. When idling it should be part open, and open right up with a rev. If it's not shutting that's not a major thing, more if it isn't opening.....still it could be throwing an error and thus the EGR is out, THAT will affect your idle / running....you're going to have to scan this, find a lappie or a buddy with Vag Com locally on here!!!
    ---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
    Quote Originally Posted by asa572 View Post
    It's something you ask the tuner to do, I'd expect anyone that has a decent diesel range of tunes would be able to do it, certainly Parso, Custom Code and Viezu can in my experience, no doubt others can too.
    Mar 2012
    Brisbane, Qld
    Quote Originally Posted by Greg Roles View Post
    I have just given the car a drive and it now idles as it used to(between 820-840rpm). Still not sure about the intake flap though. I was only turning the ignition on/off and not actually starting the car. Can I pull the large main intake pipe from the bottom of the intake flap and start the car without any damage to the engine and check what position it is at when running?
    BTW there are no error lights up on the dash. Does this mean their wont be any error codes if checked by a VAGcom or can there still be errors even with no dash light errors shown?
    Regards
    Simon
