Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: MK5 TDI Idling high
    Mar 2012
    Brisbane, Qld
    MK5 TDI Idling high
    Hi all. Was wondering if some people on this forum may be able to help me out. I drive a MK5 golf TDI 2lt with BKD engine and a couple of weeks ago it has started to idle higher than usual. It now idles at around 980rpm when usually it was around 800. Does anyone know what might be wrong or point me in the right direction?
    Regards
    Simon
    Adelaide hills, SA
    Jmac can help you with that here is his contact View Profile: Jmac - VWWatercooled Australia
    Apr 2009
    Berwick, Victoria
    My understanding. This is a micro regeneration for the DPF filter (as advised by VW at a service).
    Usally a dash warnig comes up for a major regen but you can also get minor regens.
    Idles at about/under 1000 RPM and then will return to normal in a short time.
    Mar 2012
    Brisbane, Qld
    Quote Originally Posted by davidno64 View Post
    I thought only the sport diesel had a DPF and didn't think the BKD had one. Mines got the 104kw engine. Where can I look to see if it has a DPF?
    Regards
    Simon
    Adelaide hills, SA
    Quote Originally Posted by nissman View Post
    Regards
    Simon
    You have no DPF in yours. How many kms have you done?
    Mar 2012
    Brisbane, Qld
    Have done 66000km?
    Adelaide hills, SA
    The first step is to get it scanned with VCDS or similar. The fastest and usually the most economical way is to have a mechanic look at it. Jmac is your good option, he has a lot of experience. It's hard to diagnose the car over the internet.
    Apr 2009
    Berwick, Victoria
    OOPs, you guys are correct. Got DPF on my mind at the moment, with my issues.
    This car should not have a DPF!
    Mar 2012
    Brisbane, Qld
    Just some extra information. The car still drives ok with no lack of power and still great fuel economy, it just idles high for some reason? Could it be the EGR dirty and sticking maybe?
    Jan 2008
    Sunshine Coast
    Yep, pretty likely. My TDI idles high from time to time without doing a regen, but I have messed with the engine so much, it could be anything. It is never an issue, but I your case I would put it down to the EGR, causes a lot of weird problems, gums up flaps, have you ever spray cleaned it out with intake cleaner?
