Results 1 to 10 of 20
Thread: Mk5 2.0L TDI Sump replacement
    Jun 2008
    Cronulla, NSW
    Howdy all
    Long time between posts, but back to ask a few questions before turning a wrench in anger.
    I have a 2.0L TDI (BKD engine) with a cracked sump. I have a new one being couriered today and have searched for a few days on DIY tutorials and hints and cannot find a single thing.
    I have decent mech knowledge and ramps and tools. Given this, does anyone know if it is a plug-n-play type thing or will i run into dramas and issues?
    thanks all
    Dyldo
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Jun 2008
    Cronulla, NSW
    Mk5 2.0L TDI Sump replacement-img_0067-jpg
    This guy is on passenger side of oil pan, and by my reckoning I need to remove the bell-housing to get to it?
    Dec 2008
    Sydney/Canberra
    You need to buy a long 5mm Allen key socket with a ball end. You will need to turn the motor over by hand to position the flywheel so the cutouts in it line up with each bolt to assist with removal.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Gosford Central Coast NSW
    Quote Originally Posted by Umai Naa!! View Post
    is it gasket in a tube or a real one?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2008
    Cronulla, NSW
    How would you turn the motor by hand?
    And why would the flywheel be exposed at all?
    Dec 2008
    Sydney/Canberra
    Gasket goo on these.
    '01 Beetle 2.0
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Dyldo View Post
    The cutouts are on the back side of the flywheel. They allow a more direct shot at the bolt.
    You turn the motor over by hand with a breaker bar and 19mm socket on the crankshaft bolt.
    '01 Beetle 2.0
    Jun 2008
    Cronulla, NSW
    is the crank bolt accessible whilst i am under the car on ramps?
    Dec 2008
    Sydney/Canberra
    Yeah, easy enough to get at.
    It'll be easy once you remove the lower inner guard liner. It's right there.
    '01 Beetle 2.0
    Jun 2008
    Cronulla, NSW
    Can i just flick the ignition over by small amounts to get the cutout lined up?
