Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Mk5 2.0L TDI Sump replacement
    Dec 2008
    Sydney/Canberra
    Easier to do it by hand. You'll be there all day trying to bump it over with the key to line it up. High-compression diesels tend to land on TDC virtually every time.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2008
    Cronulla, NSW
    Is it hard to turn with the compression? I have a blown disc in my back so pushing or pulling hard is an issue
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Feb 2014
    Central Vic
    Quote Originally Posted by Dyldo View Post
    Just do it incrementally and there won't be a compression issue.
    Dec 2008
    Sydney/Canberra
    Once you line the slot up with one bolt, it's only a matter of nudging it a bit further to do the next couple that are up there.
    '01 Beetle 2.0
    Jun 2008
    Cronulla, NSW
    ok, thanks guys. Trying it now.
    Jun 2008
    Cronulla, NSW
    Tried it, and no joy. the 250mm wobble extension bar and the 10mm socket (both in 1/4") just won't get in there to purchase. I could either try a 5mm ball end on the end of the wobble ext bar, or i need to turn the crank.
    What size socket for the crank? 23mm?
    Dec 2008
    Sydney/Canberra
    Either 19mm or 21mm. Can't remember which.
    '01 Beetle 2.0
    Jun 2008
    Cronulla, NSW
    Can't be, I tried 21mm and no joy.
    Jun 2008
    Cronulla, NSW
    I can't send you PM for some reason. Whats your call out rate to Cronulla if I can't sort this out?
    Jun 2008
    Cronulla, NSW
    Epic fails all along the way, but job done.
    Tips:-
    19mm 12 pt socket for turning the crank
    definitely hand-crank the engine to move the notches in the flywheel to where you can access the two nasty bolts
