Page 19 of 25 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 246
Thread: The mk3 1.9L TD power-quest
  1. #181
    Jun 2007
    Eastern Suburbs Melbourne
    oh bummer! i was looking forward to this!
    i like volkswagens
  2. #182
    Gosford Central Coast NSW
    OK, my car is back on the road finally. I fixed the wastegate issue (pull the turbo) and I also added a microswitch to control the electronic timing retard solenoid on the pump, so now I have full advance from about 10% accelerator instead of from 2800rpm. (When I say full advance, I mean full static advance, as the standard control simply retards the timing a static value (like 3-4 degrees) below normal for any given rpm, from idle to 2800. Now I have "normal" from 10% accelerator, at any rpm - what the heck does all that mean? basically I get more torque everywhere below 2800rpm, and I keep a quieter idle (sans diesel nailing) - the one disadvantage of having the "normal setting all the time).
    Its much better.
    I'm waiting on a Turbotech manual boost controller before I dyno the car. Might be tomorrow, could be next week.
    Fun Fun!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #183
    Jun 2007
    I'd love to get my hands on a mk 2 TDI. so much sootin' good fun
    edit: mk 3
    i like volkswagens
  4. #184
    All you need to do is chuck a TD in yours... you still have that?
    Loon has a couple of SDI 1.9's that are just begging to be fettled and turbo'd. I don't know why people keep going with all the hassle of wiring crap up with 1.8T's in mk1/mk2's when all you need for a diesel is 12V and a glow plug circuit. At least with a diesel you can enjoy it without the guilt or expense
    '99 A4 Quattro 1.8T
  5. #185
    Jun 2007
    I meant mk 3 TDI. oopsy. Nothing like factory goodness. I'd need to get rid of the mk 2 first. which means I have to fix it. Summer project!
    i like volkswagens
  6. #186
    May 2010
    NQ
    You sir have just givin me a goal!!!
    The thought of a MK2 TDI
    Btw read your entire thread and am quite astonished, you've turned the humble, reliable diesel into a monster....aswell as re-confirming my belief that diesels are superior
    I'll be watching this thread.
  7. #187
    Boost controller arrived and in this afternoon - 21psi in first gear up to 5000rpm and in every gear after that.
    Weeeeeeeeeeee
    Dyno later this week... i have no idea what it will do. I'll be happy if I see 110hp.
    '99 A4 Quattro 1.8T
  8. #188
    Booked in for dyno Friday afternoon. Sorry it took so long kids.
    '99 A4 Quattro 1.8T
  9. #189
    Jun 2007
    still wanna see some numbers
    i like volkswagens
  10. #190
    OK did the dyno run.
    3 runs, made 83kW every time.... thats 110hp in the old speak. I'll put up the scan of the print out when I get home later for you.
    Torque curve is interesting, and I'm a bit confused by the whole deal because the scale on the torque curve seems to be out, but the peak value (not on the curve, but the number printed) correlates perfectly to the power curve.... maybe the scale is wrong. I'll go grab another print out on monday with a correct scale.
    Anyway, it was extremely consistent and rev'd all the way to 5600RPM!!!!! Power really falls off past 4700 though.
    As for the tune, its not too smokey at the moment, i'm convinced it would make a lot more power if t wasnt running out of fuel so much at high revs. A/F ratio went from 9:1 at 1800rpm (off boost) all the way to 30:1 at peak power. Best for power in a diesel is about 15:1, so theres plenty of power to be had there, if I can mod the pump to do it.
    On the downside, its really obvious how it doesnt get going under 3000rpm, mainly because of the turbo lag. And, I can't help thinking that I could make 110hp with the K14 (though maybe a bit lower in the rpm range), and gain a bunch of torque to boot.
    We shall see. Maybe I just need ot join the VNT crowd?
    '99 A4 Quattro 1.8T
