Page 18 of 25 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 246
Thread: The mk3 1.9L TD power-quest
  1. #171
    Jun 2007
    Eastern Suburbs Melbourne
    nice, good work!
    did you convert the 02a to rod shift or install the cabkes shift mech?
    i like volkswagens
  2. #172
    Gosford Central Coast NSW
    nope, full conversion. everything 020 gone, everything 02a in. That means clutch pedal and brackets, hydraulic line, cable shift shifter box (pull off exhaust and heat shields, uuurgh), front engine mount, starter, lenghtn wiring looms for reverse switch and speedo... etc etc etc. I guess its not a huge deal really, but when your working by yourself, it felt like a lot for 1 weekend, hehe.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #173
    little update - i've done 1200km's on the new setup and not a single hiccup, leak, drip or crunch. something must be really wrong, 'cos nothings gone wrong yet
    tonight I was driving to pick up my fiance as usual, and I realised all this time nursing around the car with a slipping clutch or other similar worries, i've turned myself into such a softy. so i gave it the beans for the rest of the trip home and the car really seemed to love it
    '99 A4 Quattro 1.8T
  4. #174
    Update
    Little update here...
    Remember way back when I installed the larger T3? Well, after trying out the standard 1.6VW T3 (about 8 months) and the kkk k14 (about 3 months) I finally got around to fixing up the waste gate on my Mercedes spec bigger T3.... initially I had it in the car with the waste gate valve locked closed, so I really had to baby it around and never got a proper feel for how it could go - I only really figured out that it flowed well and could fly way past 25psi...!
    On Saturday afternoon I swapped it back in with newly customized and modified waste gate actuator (made more compact, as before it hit the firewall - its tight back there with such a big turbo) set at a stately and safe 15psi. Now that I can give it the full pedal up to the high revs.... wow!
    Its quite a different car, and just to stop typing words, I think I might even be happy enough to go try and get it dyno'd in the next couple of weeks to really see what its doing
    '99 A4 Quattro 1.8T
  5. #175
    Jun 2006
    Orange NSW
    Great work, Aydan. Cool as mate!
  6. #176
    Jan 2008
    Sunshine Coast
    So what did it run stock, and I wonder what would blow up first if you pushed it?
    Funny how long you put up with stuff mid tinker, I still haven't run my water meth I bought in Feb!!
  7. #177
    The stock turbo was a T2. I ran that up to 22psi, but stock boost was 12psi.
    The AAZ is pretty good for 30-35psi if done right (nice inlet manifold for flow distribution etc) but if done badly the first thing to go is either headgasket (ARP studs fix that) or maybe a bent conrod.
    I'm going to crank it up to 22ish psi this afternoon. The main thing that worries me with this turbo is surge at lower rpm, as it seems to be capable (if i push it) of making large boost at low rpm, I dont want to snap the shaft.
    '99 A4 Quattro 1.8T
  8. #178
    Jun 2007
    Cool as!
    It'd be really interesting to see some numbers!
    i like volkswagens
  9. #179
    Dyno tomorrow arvo.
    '99 A4 Quattro 1.8T
  10. #180
    FAIL!!!!
    You wouldn't read about it - I have to drive maybe 800m to the dyno place from my work, and as I turned out of our complex driveway, car starts making a funny noise and i discover that the brass bushing that the wastegate actuator rod passes though has popped out of the exhaust housing!
    I will attempt to fix tonight, and if I can't, it'll be atleast a week or so I reckon 'cos my weekend is full up!
    sorry guys
    '99 A4 Quattro 1.8T
