so ,some porn for you diesel heads....
i hope you all know what this isstarted to clean it up today
to give you an idea of sizing
left, k14 compressor housing, right k04 compressor housing
EGT probe mounted in the old EGR blanking plate
Yes they are 2 strokes, but you are still compressing and burning a charge the same as everything else. It was mainly a comparison, i'm not saying 2 stroke tuning directly relates to diesels..
Ideally, with a 2 stroke, you want the faintest sign of detonation pitting juuuust around the edge of the piston and combustion chamber. BUT, you have to get that without the engine getting too hot. Very tricky, and i'm not going to say much more. Wrong thread, wrong time, and it takes a lot of time and money to learn such things.![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
oil catch can i made up at work the other night. i ended up going with mild steel (it was handy) and painted black... not sure about the location yet, hence the cable ties
bad picture of the installed guages in the centre console.... from left to right - oil pressure, EGT and boost
another bad pic of the guages when ignition OFF
new 'cooler piping...
where the "magic" happens
and a little off topic - my front yard a couple of weeks ago:
my sisters GLD - used to be GLS, converted and painted by my dear old Dad
'99 A4 Quattro 1.8T
whose is the white 4 door on BBS??
Everything is looking good!
well, finally replaced clutch/pressure plate assy on saturday.
friction disk seemed ok - not too worn - but clearly contaminated with oil. shock springs stuffed as usual (180,000km). inspection of rear main seal yeilded it to be fine. im sure oil got in to the bell-housing from an oil pressure sender leak.
cleaned up the gearbox/flywheel. new pressure plate on with new bolts and new friction disk.
chucked the old original "self adjusting" crap heap of a clutch cable for brand new manually adjustable unit. woot!
i now have POWER TRANSMISSION to the ROAD!
i cant believe what a difference it is... i can actually get the benefit of my 20 odd pounds of boost now!
pulls like a freight train from 1800-3700. its still a diesel. its still not fast... but it is definately getting faster
having trouble pulling the T3 apart for rebuild..... its all siezed up. i'll get there![]()
'99 A4 Quattro 1.8T
