Well, theres been a few little things going on...
I've lately been fiddling more and more with the fuel settings on the pump, trying to minimise soot and keep some power - and i've basically cracked it with a midrange setting on the "boost pin" (adds fuel on boost) and carefully adjusted "smoke screw" (entire fuel curve adjustment).
Boost now peaks at 21psi at around 2700rpm, dropping off to about 15 psi at 3500rpm and 10psi at 4200. This is due to the governor (still stock) cutting in and spoiling all the fun - basically theres not enough fuel to make any more boost. this does however make for a clean and cool running condition - no smoke anywhere!
the only time it smokes now is off boost with a heavy tromp of the foot - quickly dissappears as the turbo spools up above 5-6psi... so she's really quote socially amicable now.
governor mod is something i really want to look at soon, as its basically the last thing on the list for this car.... apart from the T3 which is in the works
now, onto prettier things:
I aquired a triplet of nice new guages ex-ebay, from a supplier in SA. they are Racetech brand, made in taiwan. the guages came with everything needed for installation and are of very high quality, and work very very nicely indeed. stepper motor type - fully electronic with senders kept in the engine bay, so i only had to run wires into the cabin.
I got a boost pressure, oil pressure and EGT guage all for about $260. very impressed!
obviously, the EGT is the one i want to talk about....
EGT kit came complete with sender probe and all wiring, and i might add that its a very nice egt probe to install - just a good size (about 2" long with a suaged fitting so that you can adjust how far into your port it pokes.
i've mounted the probe into the EGR blanking plate that i made up for the exhaust manifold when i de-EGR'd the engine. it fits in nicely and basically sits right behind the exhaust port of no.4 cylinder.
I have found that the response of the EGT guage is pretty much instantaneous, and i have seen rises of 100degC/second, which i would think wouldnt lag much behind the actual temperature.
guage travel goes from 200C-1300C, with my own danger limit at about 750C. as yet i've not clocked anything over 520C, so i'm happy my "tuning" isnt having any negative effects on the engine.
hyway cruise at 110 keeps the guage on 200 (lower limit) which is great, and around town goes between 200 and 400.
i've also noted a direct and obvious difference with EGT and boost. more boost makes for lower EGT's in all scenario's, confirming the fact that diesels run cool and lean, rich and hot (opposite of a petrol engine). driving with a moderate boost leak (early this week i had a hose failure) i noted an increase in EGT's of about 50C across the board of driving conditions.
these observations are interesting in that it seems to make more difference to turbine temps that the mixture in nice and lean (more boost) than having a cool inlet temp (efficient intercooler). however ofcourse you'll get better efficiency andpower if the inlet air is cooler....
i'll also note that there is an obvious point where you have too much boost for the amount of fuel - as the power output suffers from larger compression losses. i see this when cuising at 0psi, and speeding up slightly so that the rev's go over 3200 and the automatic wastegating is disabled. if this happens, i get 5-7psi of boost but no extra fuel, and feel a small deceleration as the engine "loads up" with extra compression but no oomph. so, the ewasy way to tune for power is to go for a "light haze" of smoke - however this might be socially unacceptable, depending on how the people around you think. perhaps this is where the DPF came into being - allowing vw to run a tune that creates a small amount of soot (max power) and still have a slean exhaust.
anyway, pics of all the above things to come shortly.![]()
