sweet cya sunday!
i'll be there mate - nice and early and parked inside. entering the car in mk3 modified...
hope everyone else is going too!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
sweet cya sunday!
so on friday night i got back on the injector pump with my 13mm spanner, torx set and screwdriver and did a bit of tweaking.
i backed off the fuel screw a bit (yes, backed off) so that LESS fuel is going in generally. I also changed the limit switch position for the electronic wastegating to a little further along the throttle range, so that the turbo doesnt spool when im cruising at 110km/h. this means that theres no boost pressure acting on the LDA, and no extra fuel going in, so theoretically better economy. im pretty confident it will work.
i also adjusted the position of the boost compensator pin a little.
i seem to have about the same amount of power as before, but hardly any smoke at all. i've got the turbo spooling to 17psi now at peak boost, and it really pulls well, but now theres only ever any smoke at full throttle, just before boost comes on (say 3rd gear, 45km/h, foot flat). apart from that, its crystal clear out the back window!
im liking this a lot - it feels cleaner. haha. anyway, im hoping i will get a bit better economy now. im keen to break the 5l/100km mark and show all you TDI guys that you can do it the luddite way aswell![]()
'99 A4 Quattro 1.8T
good on ya Aydan, love ya style and the fact your not scared to get in there and do it yourself![]()
hi again guys,
well not sure bit i think i might be killing my turbo....
i'm getting a bit more whistle than i used to and apart from that my exhaust smells oily, so i reckon i'm leaking a bit of oil from the turbo into the intake.... might have a looky at the intercooler on the weekend, i suspect its filling up with oil ha.
so, i guess its time soon for a k04!
'99 A4 Quattro 1.8T
maybe you've just done the seals...?
silver lining to every cloud...
Sorry to hear that..but I would have thought the main point of oil ingress into your inlet would be through the crank case venting. Sure all total loss turbo bearings leak oil into the inlet / exhaust a little, but my money is on the extra boost getting past the rings and causing extra pressure in your sump, and thus more oil and vapour coming out the vent. I'm only at 9000kms now, and I've dumped a good 200mL plus of oil from the bottom of my provent oil vapour filter doobie, so you can just imagine what a few hundred k's does for an inlet oil wise!
I'd be looking at the oil film before, and after the point at which the vent system enters the inlet. I know TDI-club goes on and on about cleaning intercoolers and the amount of oil ingress through the vent system.
Good luck, and I hope it's not the turbo seals!
'99 A4 Quattro 1.8T
