Originally Posted by
gregozedobe
I would have thought there may be possible gains to be had from better gas flow by modding intake, valves, cams, compression ratio, intake air temp (eg more efficient intercooler), turbo capacity/efficiency or exhaust ? I didn't realize diesels were THAT different to petrol engines (except for being not very amenable to tuning for more power at higher revs)
ahh - sorry about the misunderstanding -
All aspects of the engines performance in terms of engine management (i.e. air and fuel intake) are goverened by the injector pump and turbine wastegate.
this is not the same as saying that other improvements such as bigger valves, reducing flow losses and optimising mechanical efficiencies do not have the ablility to increase the power output - merely that these things are not part of the engine management...
Indeed, adding larger valves would be desireable - if it were possible! but alas, there is no more room for larger valves, and in fact there is no real need in terms of max horsepower that is likely - the turbocharger more than makes up for that. likewise, there not a lot of improvement possible with the cam timing (for IDI diesels) either.
however, portmatching and polishing does work well for diesels, as well as ceramic coating of the piston crowns, and exhaust valve faces.
now, there are gains to be had in the areas of compression - lowering the compression from the stock 22.5:1 down to about 18.5:1 would likely be optimal - however this has implications for cold starting behavior etc etc - and is far beyond what i want to do with my daily driver!
when i come to modify my 1.6TD for the mk1 hillclimb/rally/whoknowswhat car, then i will certainly look at these things... but under 150hp, i would be wasting my own time and money bothering on some of the more serious modifications for the 1.9L AAZ in my daily driver.
And, please note that I have already mentioned about modifying the exhaust on the car in the first post...
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
