Page 1 of 25 12311 ... LastLast
Results 1 to 10 of 246
Thread: The mk3 1.9L TD power-quest
    Gosford Central Coast NSW
    So, i htought i'd start a thread to give some new life to this slow diesel forum (no pun intended!).
    Late last year I aquired a '94 Mk3 CL Golf. Personal import, 1.9L Turbo-diesel, (engine code AAZ). Note, this is not TDi, its indirect injection like the old mk1!
    On the face of it, the mk3 is a pretty car - aftermarket dual round headlight clusters, dark tails and fogs, and ofcourse the elegant Speedline 16x7.5" alloys.
    The car was a bit of a dawdler when I picked it up - completely standard engine.
    This early model mk3 but late model IDI diesel has the same old VE injector pump that the mk1 uses, much to my joy - it is a highly tuneable item, with a couple of minutes of turning screws the car can become a totally different beast!
    the Manual states the stock output to be a dithering 68hp - and i'd believe it! however, theres no question that something was still working at low rev's, because it would still pull well up long hills.
    The k14 turbocharger is well matched to the engine for gnereal driving, as i realised after my first modification - a boost guage into he centre consolse, in order to see just what it was doing.
    I was glad to see that the stock boost was right where it ought to be at 12psi.
    my hunger for more power was overpowering, and as such the injector pump became the focus of my attention. The so called "smoke screw" was the first place to go, and with a small adjustment i soon realised just how under-fuelled this thing was - with just an 1/8th of a turn it went from "slug" to "gets out of its own way" which made me immensly happy.
    next, the timing retard solenoid got my attenstion - this retads the timing at low engine speeds in order to lessen the diesel rattle - i couldnt care less! the darn car gained more than a few extra horses under 2800rpm once that was sorted.
    Then i began to wonder about intercooling. I was sure that the car could take more air and fuel, but i wanted to build the foundations for future tuning, so more air came in the form of an intercooler.
    some basic thermodynamics says that if the turbo is compressing the inlet air to 12psi, then it could be as hot as 130degC on exit! if i could get an intercooler to bring this down atleast to under 60deg, i would get an extra 10-15% more air into the engine - without even increasing the boost!
    after a few trips to the wreckers and a lot of headaches, the intercooler from a Pug 405 SRDT found a new home above the gearbox in the engine bay, with a stainless steel cowling and ducting for fresh air from the now functional CL lower air intakes on the front bumper.
    10-15% more air then translates into 10-15% more power once the fuelling is up to it, and the difference was remarkable - this car now moves very well indeed!
    Up to now, the last modification was the boost compensation device on the injector pump. The pump uses a contoured pin attached to a diafragm to make fuelling adjustments - and the shape of the pin gives an indication of the fuel curve, so to speak. the standard 1.9 pin is flat, with a small bump increasing fuelling a tiny amount as boost reaches 9-10psi.
    I sourced a different boost pin from a 1.6 TD pump which gives a more power oriented fuelling curve - a gradual increase as boost goes up - and this has since transformed the car into something truely fun to drive - much more power than the 1600 big carbie LS with extractors that it lives next to in my garage!
    I would guess that the modifications so far have given me close to 95hp, a good 40% increase atleast - but though this doesnt sound a lot, it is the extra torque that makes the real difference. from 1500-3500rpm, the little diesel accelerates relentlessly, and its fair to say that the 60-80 time is similar, in the same gear, to the 100-120 time.
    all of this without even changing the restrictive exhaust system which is seriously impeding performance..... no prises for guessing whats coming next.
    I intend to keep this thread updated as more developments occur, but suffuce to say, im aiming high, but reliable.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    Eastern Suburbs Melbourne
    Nice little write up, I look further to seeing further mods! I would love a diesel golf, but being as rare as something that's really rare, I don't think it's going to happen anytime soon!
    Have you thought about popping it on a dyno? It would be interesting to see indeed!
    i like volkswagens
    Nov 2007
    The Land of Oz
    Fuel consumption?
    Ayden... Have you had a chance to calculate the changes to fuel consumption as you progressively modified the motor? I bet the intercooler had a beneficial effect!
    are there chips available for this engine? good on ya, this is very educational
    Jan 2008
    Melbun
    nice write up thanks for that keep it coming
    2x Caddy, 1x Ducato
    Quote Originally Posted by cetane View Post
    some consumption figures:
    just after purchase, no modifications - 6.6l/100km combined
    after timing retard disabled - 5.9l/100km combined
    turbocharger limit switch adjustment - 5.8l/100km combined
    intercooler - 5.5l/100km combined
    this is based on what i call "normal routine driving" however, the use of b100 seems to push consumption up by 0.6l/100km in all conditions, and also the increased fuelling allows me to blow out consumption to as high as 6.9l/100km on biodiesel right now, with lots and lots of heavy/fast driving.
    the net affect has therefore been beneficial but for allowing me to make consupmtion worse by driving very hard...
    '99 A4 Quattro 1.8T
    Quote Originally Posted by GoLfMan View Post
    This engine basically zero electronic engine management - everything is mechanical. there is no ECU... thus my happyness at the car because of its "tunability" - i can tune the engine to my like's without having to play around with electronics. all aspects of the engines performance are governed by either the injector pump or the turbine wastegate.
    '99 A4 Quattro 1.8T
    i would certainly like to put numbers in place of words - but not until i get my new exhaust system on the car, since at the moment it is so restricted that i'm afraid to use full throttle for longer than about 5-8 seconds, for fear of high EGT's melting my turbo/pistons etc.
    '99 A4 Quattro 1.8T
    that freaking awesome mate that makes life all that much easier!!!
    Canberra
    I would have thought there may be possible gains to be had from better gas flow by modding intake, valves, cams, compression ratio, intake air temp (eg more efficient intercooler), turbo capacity/efficiency or exhaust ? I didn't realize diesels were THAT different to petrol engines (except for being not very amenable to tuning for more power at higher revs)
