Results 1 to 4 of 4
Thread: mk1 GLD
    Andrew Powell Guest
    mk1 GLD
    Does anyone know how to fix the following problem in a mk 1 diesel:
    filling up the fuel tank is difficult because the fuel does not flow easily into the tank. I can only fill it up at a trickle pace before the trigger clicks and consequently takes ages to even put in 20 litres at a time. it makes a sucking noise as the diesel drops to the tank.
    also:
    where are fumes most likely to be entering the cabin? i've repleaced the rear hatch seals.
    thanks
    Jun 2007
    Eastern Suburbs Melbourne
    hi mate.
    hopefully these might help a bit, but wont be surefire fixes.
    The fumes might be coming in through the vents. There is a seal that sits on the rain train, which is meant to stop fumes coming from the engine bay to the cabin. Mine was completely gone when I first had my car!
    as for the filling up. It's possible you are just putting the filler too far down the next. I had an issue similar to this when I was new to my car, but if you hold the trigger back a little bit (ie no all the way in) you might find that might help. It might not, but something to try.
    i like volkswagens
    Andrew Powell Guest
    thanks for the ideas. I will have a look at the vents
    as for the fuel , I've tried that already. seems like is something blocking it, like a partially blocked drain. The fuel goes down into the tank, just really really slowly. If I fill it up too quickly it overflows which is messy.
    Nov 2007
    The Land of Oz
    Vents
    The tank is vented to allow air to escape during filling. (A bit like trying to fill a bottle with water without an air gap at the top.)
    It's possible that the vent pipe is blocked or you're blocking it with the filler gun. (Pre 1980 models have 2 vent pipes, post 1980, 1)
    This could also be the source of the fumes.
    I have no problems filling my GLD.
    Oh....Welcome to the Diesel Club!
