Anyone recommend which oil is best for a mk1 GLD with about 200k on the clock?
CK engine.
Cheers in advance
CK engine.
Cheers in advance
'79 GLD
If the engine is in good condition I would go with 5W40 or 10W40 oil, Total or Mobil1. Probably the easy get oil for your engine would be Penrite HPRDiesel 15W50 or HPR Diesel 5W40.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks for the quick response! The engine might be fuming a little, should that affect my decision on which way to lean?
'79 GLD
i run penrite 20w60 'cause the turbo tends to increase the blow by gasses. I also fitted a scavenger on the breather pipe.
Rob
mk1 gld with turbo and five speed box
Yeah the Penrite 15w/50 is a pretty good option, its quite well priced too. GLDoldcoot's engine has seen a lot of work![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Have used the Penrite HPR before with no issues.
