Our one revs out to 5, needs more power though, gotta convince dad to fit a decent bar and plate to it :p
Well cam plates and governor mods and spring are a bit more advanced mods then the max fuel screw and boost pin angle. Can't exactly change them without the pump off the vehicle. But yeah it does make it simpler.
ok.. so the story is.. i have a chinese turbo. its a K04 copy made by the reputable manufacturer "YEQI". Definitely my favourite brand!
anyways, its crap. So.. Aydan found a real K04 on the net for 300 bucks. so i bought it. Its a genuine 3K K04-003 from a chrysler 2.5.
here are the two turbos side by side
the problem is, that the turbine inlet on the new turbo doesnt match my exhaust manifold. so... we pulled off the turbine housings to see what we could see
here they are again side by side
They looked pretty similar, so all we had to do was swap the turbine housings!!
almost..
the problem was that the turbine blades were just a smidgen taller at the outer diameter on the 3K turbo, which meant the blades contacted the casing from the YEQI. so... we used the backing plate from the YEQI.. with a bit of modification:
we got this!
which when placed under the turbine housing, gave the perfect clearance for the turbine wheel!
a quick test fit:
then to mount the wastegate actuator. had to tap some holes on the 3K turbo. then:
TDI mk1 on the road!!
its alive!!!!
FRANKEN TURBO:
Nice one. Hope it all holds together! Wouldn't want to see half a turbo flying through the bonnet...
well, a small part of me would, but that's for another day![]()
That would be well wicked!
Note to self: Carry video camera wherever you go..
I have total faith in Mike and Aydan's Franken turbo expertise.
Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
1976 LS parts vehicle
Used to have: Mk1 Swallowtail LS DIESEL!
nice one mate, as Jarred said i hope that housing is good quality
you guys are the ultimate DIY's!!![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
