Hello diesel people.
For those that arent frequently browsing the mk1 forums you may not know im trying to build a TDI mk1.
I'll be keeping the tech chat in this new thread in the diesel section to keep the forum more organised.
I'm using a 1.9 1Z which comes in late 90's mk3, passat, T4 etc in the rest of the world.
The engine was imported without an ECU etc. so Ill be ditching the electronically controlled pump and going with the so called "M-tdi" option which uses the older mechnically controlled Bosch VE pump with a TDI camplate and rotor which bring up the pressure to suit the TDI engine.
I bought an M-tdi ready pump straight from a pump-builder in the US which uses an AAZ (1.9td indirect injection) pump body. This should hopefullly get the 1Z running and then I cant play with governers and timing to get the car running how i want it.
this is the 1Z in all its glory this morning.. after a bit of a tidy up and pulling off all that pesky electronic wiring
then good bye to the evil electronic controlled injector pump
this is the 1Z electronic pump on the left, and my rebuilt AAZ (indirect injection 1.9) pump on the right. The AAZ pump has TDI camplate and rotor in it, which makes it able to run higher TDI pressures, but without needing an ECU to run the pump, making this a so-called "M-TDI"
fitting up the new pump
here is my cheapo chinese turbo. It's a copy of a k04 turbo. I dont think i'll be using it. Ive got some other options as i have a 4 stud manifold from my 1.6 td which means i can use a k14 or T3. The 1Z came out with the both the k03 or k14 originally.
Currently held up as I need a new injector pump pulley to fit the AAZ pump. Should be able to get one from the states pretty cheap.
