Noice.
Blow back is what you want in a diesel
finally located a MkIII TDI.
Its original everything, including an auto box.
Interested in an economical daily driver for the teen, nothing flash
Would have loved manual, not sure what else I would change, done 211,000 kays some blow-back, otherwise sound, all maintenance suggestions welcome.
http://liveimages.carsales.com.au/pr...616580476.jpg/
MY09 Golf Candy White 2.0 TDI Pacific
MY95 Golf III TDI
Noice.
Thanks mate, what would I know?
All good. Cant find the trip meter
MY95 Golf III TDI
And they say you can't find Hens Teeth!
Pretty lucky to get an Auto.
Once you get it take the Intake off and clean it out... as well as the charge piping and Intercooler...
Intake will be choked with muck and intercooler will have oil in it... It is not serious and ALL TDI's have this problem.
Cleaning them will Help breathability and reduce the soot out the back and up the performance back to original - You will ceiratinly need it with the Auto as it is slugish in a TDI.
Does it Have Criuse Control? - It you want it... all you need to add is the Steering Colum Stalk and hook up the wires... it's all Controlled via the ECU
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
Thanks Gigitt,
And thanks for the tips, it certainly needs some performance happening.
I will also be guessing as to which pipes are which, but cleaning anything can only help...
Service records are good for all but the last 30,000, so not assuming.
And we feel lucky, as some in here will know, been looking for a good while
It does have a cruise control stalk.
I am not sure how to engage it, different from the MkV anyway.
I wasn't aware the auto was rare, would have preferred manual as it is sluggish, but that's what they had, so.
Will get some pics up. I think I have to revisit photobucket anyway
MY95 Golf III TDI
To find the trip counter, turn the ignition on, and press the button under the odometer, it switches between odo and trip, but only with ignition on. To engage cruise, turn the front switch situated about 3/4 in down the stalk to the left and then press the switch on the end of the stalk in at the desired speed!. Good luck, I would never call my Tdi sluggish, so either it's the auto sapping the power or mine's been flashed!
Mk3 Golf Tdi about to sell
Mk 1 Golf GLD somewhere in a paddock!
Mk1 Golf Cabriolet
MK2 Golf Turbo diesel engine and 5 sp gearbox
Thanks will try the CC and report back.
Got the odo and clock sorted thanks.
Seems we have a 1Z diesel 1.9 turbo and CKZ auto box.
MY95 Golf III TDI
Stock 1Z motor AFAICS...
MY95 Golf III TDI
looks like you have a remote 2nd fuel filter fitted on the firewall left of the coolant expansion tank.
That is exactly where I fitted my Oil Air seperator Catch can.
I have only see a remote filter on one white auto TDI I test drove about 10 years ago out West of Sydney when it poped up for sale.
Here is an old shot of my engine bay:
