Results 1 to 10 of 84
Thread: Mk III TDI
yowie Mk III TDI 28-07-2012, 03:46 PM
HaydEn Noice. Blow back is what... 28-07-2012, 04:49 PM
yowie Thanks mate, what would I... 28-07-2012, 08:58 PM
Gigitt And they say you can't find... 29-07-2012, 04:24 AM
yowie Thanks Gigitt, And thanks... 29-07-2012, 08:17 AM
sparkie To find the trip counter,... 04-08-2012, 11:27 PM
yowie Thanks will try the CC and... 05-08-2012, 03:04 PM
yowie http://www.vwwatercooled.com.a... 05-08-2012, 06:35 PM
Gigitt looks like you have a remote... 05-08-2012, 07:19 PM
yowie Yes, its being coy in the... 07-08-2012, 07:05 PM
Gigitt actiually the John West... 07-08-2012, 07:24 PM
yowie Thanks for explaining that... 07-08-2012, 10:41 PM
yowie Soo, I have to report some... 17-08-2012, 03:08 PM
Garbon These are great cars! ... 19-08-2012, 07:24 AM
yowie Agreed, great cars. Mine... 19-08-2012, 12:45 PM
yowie Ahh, a "new", second-hand... 23-08-2012, 07:05 PM
yowie So, I got a letter from the... 29-08-2012, 08:35 PM
Garbon Thanks for the info on the... 02-09-2012, 06:02 AM
yowie No worries and absolutely... 05-09-2012, 09:00 PM
yowie Today I discovered the... 08-09-2012, 01:12 PM
gldgti You can replace the shelf... 08-09-2012, 06:20 PM
Gigitt The drivers seat in my 1996... 08-09-2012, 07:12 PM
yowie Thanks for that info guys. I... 09-09-2012, 08:40 AM
Gigitt Why don't just put the toll... 09-09-2012, 09:28 AM
yowie Thanks Gigitt. Good to know... 09-09-2012, 11:30 AM
gldgti Yeah trim levels on mk3... 09-09-2012, 06:19 PM
yowie And who knew? The car came... 07-10-2012, 07:20 PM
Gigitt Yeah the keys have imobiliser... 07-10-2012, 09:14 PM
yowie Thanks for that, saw the... 08-10-2012, 05:48 PM
Gigitt Chip in key works like the... 08-10-2012, 06:47 PM
yowie SOoo, No ABS, and still no... 16-10-2012, 03:44 PM
gldgti for the high beams - pull the... 16-10-2012, 03:51 PM
yowie Thanks for that, gldgti. The... 16-10-2012, 07:54 PM
gldgti The headlight switch pulling... 16-10-2012, 08:04 PM
Gigitt mine is 1 click out for front... 16-10-2012, 09:19 PM
gldgti thats what i said.... 17-10-2012, 10:20 AM
Gigitt Yes semantics... but his pull... 17-10-2012, 04:09 PM
gldgti hopefully before its too dark! 17-10-2012, 07:38 PM
Gigitt lol :p 17-10-2012, 07:45 PM
yowie Gigitt and gldgti, thank you... 18-10-2012, 08:06 PM
Gigitt With the Fogs... Front Fog... 18-10-2012, 10:08 PM
yowie My brain is full! Thanks... 30-10-2012, 03:27 PM
gldgti yes, or even the haynes for... 30-10-2012, 04:35 PM
yowie Ah a wiper stalk issue. I... 12-03-2013, 08:03 AM
yowie OK, I found this info about... 12-03-2013, 11:47 AM
Gigitt from memory 1 Click up is... 12-03-2013, 01:22 PM
yowie Thanks Gigitt, All good.... 13-03-2013, 01:37 PM
yowie New issue: Got the car back... 10-04-2013, 09:21 AM
Gigitt been there done that - but... 10-04-2013, 07:13 PM
Gigitt Oh - forgot you need... 10-04-2013, 07:17 PM
yowie Gigitt, Yeah, thanks for... 11-04-2013, 08:48 AM
Gigitt if you have the plastic door... 11-04-2013, 12:27 PM
yowie Thanks, I will see how I go.... 11-04-2013, 07:48 PM
Gigitt if the button does not want o... 11-04-2013, 09:54 PM
yowie Really useful to have that... 12-04-2013, 07:41 AM
Gigitt I was just surfing ebay and... 13-04-2013, 08:10 PM
yowie Yes, finally got around to... 20-04-2013, 07:13 PM
yowie Good news. Got my hands on a... 21-04-2013, 04:07 PM
yowie Hello VW Watercooled, So... 23-08-2013, 05:18 PM
Gigitt immobilizer? VCDS scan... 23-08-2013, 06:32 PM
yowie Immobilizer would fit, thanks... 23-08-2013, 08:49 PM
yowie Gigitt, thanks for the... 24-08-2013, 08:56 AM
yowie In the interests of keeping... 15-12-2013, 03:09 PM
gldgti Don't worry about air in the... 24-08-2012, 06:51 PM
yowie Thanskk gldgti, great advice.... 28-08-2012, 06:36 PM
Buller_Scott dont be worried about oil in... 05-08-2012, 11:23 PM
Gigitt Oh dude... :facepalm: Salt... 15-12-2013, 10:15 PM
yowie Thanks, Yes, I thought the... 16-12-2013, 07:31 AM
yowie So the car failed to stop... 13-01-2014, 08:24 AM
gldgti could be leaking seals in the... 14-01-2014, 08:36 AM
yowie Pulling the rear wheels and... 14-01-2014, 11:10 AM
yowie I am recording this to save... 28-02-2014, 01:15 PM
yowie OK, so now I am saving myself... 06-03-2014, 01:06 PM
Gigitt Mk III TDI 06-03-2014, 01:18 PM
gldgti Just give tooleys the VW part... 06-03-2014, 05:24 PM
yowie Thanks, have discussed with... 14-03-2014, 08:04 AM
yowie Have lurked but not posted... 11-01-2016, 12:59 PM
yowie not what I thought 11-01-2016, 06:08 PM
yowie MAF! Sorry 11-01-2016, 09:53 PM
gldgti You said previously there was... 12-01-2016, 03:45 PM
yowie Thanks gldgti, agreed. I'm... 13-01-2016, 12:00 AM
    Mar 2009
    Brisvegas
    Yes, finally got around to buying in parts and pulling the handle, after buying vaseline and new pliers just in case.
    Turns out it is a simple paddle with a hook and spring.
    I this case the hook broke off.
    Luckily it left a bit of hook in the hole so the spring stayed in place which is why the key was returning to vertical all the time.
    That has also meant the spring stayed on the lock instead of falling inside the bottom of the door.
    Not so luckily, the hook I ordered is too big to go in the hole/ring bit on the end of the barrel.
    I was careful to tell the parts ppl which year model I had as there are two hook and loop sizes.
    It would be good to know which is which in terms of models.
    So, whether I have a replacement lock already and need the younger hook, or a later model hook.
    Monday will tell.
    Once I have the right size hook, should be a pretty simple fix. I am not looking forward to replacing an entire barrel, that looks like more hours than I can concentrate
    MY09 Golf Candy White 2.0 TDI Pacific
    MY95 Golf III TDI
    Mar 2009
    Brisvegas
    Good news.
    Got my hands on a Tooleys lock kit and replaced the whole thing.
    I was very hesitant when I saw the barrel and the seven little keys and matching teeny springs.
    Worked a charm once I found a prising tool to get the seven tiny key springs out of the lock.
    And petroleum jelly is great for lubing and keeping it all together while you go.
    The kit included the bigger new hook, so all good. I will get another for the passenger door.
    There is a helpful youtube here- VW A3 MK3 Golf Cabrio Door Lock Repair DIY - YouTube
    And also a helpful thread in here that hasn''t had a post since 2008.
    If following Youtube man, watch for the fudge while fitting the last bigger spring to the hook, that is the spring that holds the hook and paddle out straight. I struggled for ages trying to assemble it as he suggested.
    Then I noticed the spring has ground ends and was able to thread it around the hook after I had inserted the hook into the loop.
    The Youtube clip shows the hook being inserted with the spring already in place.
    But he also cuts the video so you don't see how they actually go together
    MY95 Golf III TDI
    Mar 2009
    Brisvegas
    Hello VW Watercooled, So another six months and all good, until today.
    Wouldnt start in the cold. Battery is new-ish.
    Sometimes the after-market turbo-timer acts up and needs neutralising. (Process is to turn the motor off, hit the turbo timer zero switch, and start up.)
    Low oil, really low, after a country trip. Go buy Penrite Enviro+ ,505. 504-507, 5W-30 ($82 Supercheap, not,) in case that is the reason.
    No dice.
    So, I chickened-out and called the roadside assist mechanics (RACQ). They isolated the turbo-timer, but that made no difference.
    The engine starts and runs about 3 seconds and then cuts out.
    This is the same way the turbo-timer plays up.
    So unless a brainwave intervenes, we are getting it towed to local garage.
    Any suggestions would be very welcome.
    Cheers, Yowie
    MY95 Golf III TDI
    Nov 2005
    Sydney NSW
    immobilizer?
    VCDS scan would be good.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Mar 2009
    Brisvegas
    Quote Originally Posted by Gigitt View Post
    immobilizer?
    Immobilizer would fit, thanks Gigitt. I guess we will see.
    I dont have access to VCDS and assume they/it wont be cheap- I dont have the laptop either .
    I guess thats what garages are for.
    MY95 Golf III TDI
    Mar 2009
    Brisvegas
    Gigitt, thanks for the suggestion.
    It was the chip in the key.
    Car started first go when I tried it with the spare key which is the factory one.
    Back to the random local key cutter to see what, if anything, he has to say.
    MY95 Golf III TDI
    Mar 2009
    Brisvegas
    In the interests of keeping my silly questions in the one place...
    Yesterday I was using the Mk 3 to launch a boat. Diesel pulled it easily on the 8-1 ramp. However at the time there were people standing between car and trailer and I couldnt move it, a wake wave came by and submerged the rear axle.
    I hosed underneath as its a salt river, and noticed the S/S muffler for the first time.
    Question is, do I need to pull the rear wheel bearings or are they sealed well enough?
    I have read the manual and they look closed in but any more intelligent views are very welcome.
    Is there anything else needs servicing as a result, aside from my brain?
    Thanks in advance.
    MY95 Golf III TDI
