Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 84
Thread: Mk III TDI
  1. #51
    Mar 2009
    Brisvegas
    OK, I found this info about rear wiper on-off switching on a UK website,
    GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
    so it looks like a wiring issue. When they say tap it, not sure in which direction.
    I think I tried them all, o well hose and a few experiments, shall see.
    Cheers,
    Yowie
    MY09 Golf Candy White 2.0 TDI Pacific
    MY95 Golf III TDI
  2. #52
    Nov 2005
    Sydney NSW
    from memory
    1 Click up is Intermittent mode (Up = anti clockwise)
    2 click up is standard front wiper speed
    3 click up is Fast front wiper Speed
    Push towards front of car for Rear wiper control (On/OFF/Water)
    Pull towards steering wheel for Front Wiper Water
    The intermittent front wiper function is TIME dependent.
    That is 1 click up to turn on INTERMITTENT WIPER. Default is ~4 seconds between wipes.
    If you want it to wipe at a faster rate, turn it off - count for the number of seconds you want it to be off then 1 click up to turn it back on.
    You have to do this between wipes - ie not when wiper is half way through a wipe. if you turn it off 1/2 way it cancels the timing.
    So to Change the INTERMITTENT TIMING....
    1 click up to turn on INTERMITTENT Wipe, then 1 Click down after 1st full wipe, then count 1001 1002
    then 1 click up to INTERMITTENT Wipe and now your wipers INTERMITTENT setting is now 2 seconds between wipes.
    You can set the INTERMITTENT wipes upto 10 sec. after 10 sec wait the timer returns to default ~4 seconds.
    To Cancel INTERMITTENT Wipes you turn off for longer than 10 sec or use Normal or Fast wiper mode, or set INTERMITTENT Wipe to another Speed.
    For the REAR wiper you turn on by push lever towards the front of car (momentary ON) then push again to turn off. Push and Hold for rear wiper and water.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
  3. #53
    Mar 2009
    Brisvegas
    Thanks Gigitt,
    All good. The rear wiper turns on (auto intermittent) with a brief push towards the front of the car.
    To turn the rear wiper off, once its in intermittent phase, it requires another tap in the same direction, but this has to be done during the wipe phase.
    If you push down between wipes, it just re- wipes instantaneously.
    The front wipers work as you say, with the exception that, on my car, the intermittent on is a down motion, towards driver's right knee, and the constant wipe functions are up towards the windscreen.
    All good for the test, even gave it a (brief) tub.
    Thanks again,
    Yowie
    MY95 Golf III TDI
  4. #54
    Mar 2009
    Brisvegas
    New issue: Got the car back from a service at local garage and thought the driver's door lock was a bit loose.
    Today, when I went to drive the teen to a work experience thing in the rain, I found it wont open at all, and that was the one door lock that worked.
    I think they probably turned the lock a bit hard and broke the pin or whatever goes when this happens. The key now free turn 180 degrees either direction...
    Question is, what to do?
    I can only see a broken window and major repair bill in the future
    Any suggestions would be gratefully received at this stage.
    And, of course, its in a two hour daytime zone, and at the mercy of council parking officers.
    MY95 Golf III TDI
  5. #55
    Nov 2005
    Sydney NSW
    been there done that - but not on my Mk3 TDI - mine is Bullet Proof
    I have done 3 door locks on 1998 6N Polo's... the internal key barrel once the correct key is inserted unlocks and it can rotate. The Barrel has some pins at the back that are pushed against some springs that allow it to return back to center. These pins also engage the main housing and allow the door to 1) on a half turn to electronically un/lock when it touches the electronic switch by turning on the central locking pump. 2) if you keep turning further then the pins engage the mechanical lock an you can manuall un/lock the doors (eg when no battery conneted)
    So these pins break at the end of the barrel.
    if one of the pins breaks then you can only either open or close depending on what pin is still intact.
    So basically you have to buy another door lock. Wreckers only sold me the whole handle and lock together.
    You pull the handle apart and just replace the broken barrel pin part.
    You slide you key into the lock to take the barrel off and put your lock into the good barrel.
    Now I'm going by memory as I did thes about few years ago.
    When I talk about 'barrel' it might be just the rear part that breaks not the barrel itself - i can't remember.
    I do know that you should take the broken handle off the car and take it with you to the wreckers... the Polo's came with 2 types of barrel pin mechanisms and they are not interchangeable - but the rest of the handles parts are - pretty screwy!
    Also with the polo's it did not matter which side of the car handle you buy - just make sure the pins mechanism is the same.
    Now I think the Mk3 Golf door locks are similar internal working to the Polo's. Just the keys were different. Polo's had similar internal worm cut squigles as like current keys. My Mk3 Golf keys are edge hill and valley cut.
    I think I took pics but don't know where they are - sorry.
  6. #56
    Nov 2005
    Sydney NSW
    Oh - forgot you need emergency car access... sorry you open the boot to open the rear doors so you can open the fronts using the Pull Up Door pins.
    Now this will kind os suck if you do not have the plastic door pins and only the threaded wire and the threads go pretty low into the door.
    Oh... I have a remote car alarm on mine so using the keys is very sledom.
  7. #57
    Mar 2009
    Brisvegas
    Gigitt,
    Yeah, thanks for both those posts.
    Eventually, in the rain, we got in through the boot after the RACQ guy prised the drivers door and jiggled the door button, which is a plastic stalk type thankfully. It didnt open the door, but for some reason, the boot opened.
    It could be my error, but before that, I thought I was locked out of the boot too.
    And having struggled into the front seat, not as flexible as I used to be, I found the door locked and any attempt to open the door was repelled by the vacuum system, so NASCAR through the window, which is the Armstrong manual winder-type. However, on starting the car, all the doors have unlocked and now wont re-lock.
    I have ordered both replacement lock eccentrics and a replacement barrel kit. If not the drivers' door, the passenger door will need a new kit, will see. And am buying a Bentleys.
    I also got a Torx set so I can remove the door handle. In other threads, they are Allen keys, but not mine.
    Thanks again, fingers crossed it will be OK over the weekend, and I don't drop anything vital where I cant retrieve it.
    MY95 Golf III TDI
  8. #58
    Nov 2005
    Sydney NSW
    if you have the plastic door pins, you should still have been able to open the doors... well maybe... Mk3 are supposed to have a nice feature of deadlocks when using the keys
    you can test this by having the window down and locking the car then testing the door pin 10 minutes later to see it will unlock the door.
    I don't know if you will find any of this in the Bentley manual except taking the door handle off the car.
    I have a Bentley and did not use it to help me pull the handle apart to fix the barrel thingy with the Polo's.
    I'm mechanically minded so it was not hard to figure out what was wrong and how to fix it.
    If you have any issues, take pics and post them up. I probably can still walk you though the fix.
  9. #59
    Mar 2009
    Brisvegas
    Quote Originally Posted by Gigitt View Post
    Thanks, I will see how I go. The challenge of posting pics sounds harder than fitting a door lock back in
    Probably needed the Bentley anyway, but point taken.
    I tried the windows down thing. It totally refuses to lock as is. No big deal as we can get it off the street nights.
    Will let you know~~
    MY95 Golf III TDI
  10. #60
    Nov 2005
    Sydney NSW
    Quote Originally Posted by yowie View Post
    Will let you know~~
    if the button does not want o stay down cause the central locking keeps activating and opening the doors, then sounds like a broken piece of the key/lock mechanism is jamming the electric switch and it gets activated thinking you wanted to open the door.
