from memory
1 Click up is Intermittent mode (Up = anti clockwise)
2 click up is standard front wiper speed
3 click up is Fast front wiper Speed
Push towards front of car for Rear wiper control (On/OFF/Water)
Pull towards steering wheel for Front Wiper Water
The intermittent front wiper function is TIME dependent.
That is 1 click up to turn on INTERMITTENT WIPER. Default is ~4 seconds between wipes.
If you want it to wipe at a faster rate, turn it off - count for the number of seconds you want it to be off then 1 click up to turn it back on.
You have to do this between wipes - ie not when wiper is half way through a wipe. if you turn it off 1/2 way it cancels the timing.
So to Change the INTERMITTENT TIMING....
1 click up to turn on INTERMITTENT Wipe, then 1 Click down after 1st full wipe, then count 1001 1002
then 1 click up to INTERMITTENT Wipe and now your wipers INTERMITTENT setting is now 2 seconds between wipes.
You can set the INTERMITTENT wipes upto 10 sec. after 10 sec wait the timer returns to default ~4 seconds.
To Cancel INTERMITTENT Wipes you turn off for longer than 10 sec or use Normal or Fast wiper mode, or set INTERMITTENT Wipe to another Speed.
For the REAR wiper you turn on by push lever towards the front of car (momentary ON) then push again to turn off. Push and Hold for rear wiper and water.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
