Yeah it's pretty tight. And if I trim the engine cover a little it'll go back on and look OEM-ish
Wow... Just came across ur build thread and how u close to selling ur car. Exciting thread!
Did u color code ur rough plastic bumpers urself too or it was sent to a body shop?
I colour coded them myself. High full primer. Lots of sanding. The. 2 pack silver and 2 pack clear
I'm amazed at how you color coded the plastic parts urself! Any guides or tips? Tools like spray gun, air compressor....?
Yeah high full primer. Lots of sanding. Colour matched acrylic paint. 2 pack clear paint though. All sprayed on low pressure from a 30 odd litre air compresser and spray gun of course. Pretty basic spray painting stuff
---------- Post added at 10:50 AM ---------- Previous post was at 10:48 AM ----------
I'll be painting a gti rear balance soon. I'll do a few piccies along the way
Thanks for sharing! Yea a few pics wld truly be appreciated! I'm feeling a little daunted as to painting it myself tho.
What grit sandpaper did u start w to get rid of the textured surface? And do progress down to finer grit along the way? Did u have to wet sand your acrylic paint down and buffing it before putting on the 2pac clear coats?
You make it sound easy....
it easy!
i forget what grit i used, i didn't sand down the textured plastic, just high fill primed until it had filled in the bumps smooth, then rubbed it back with up to 2000 grit i believe.
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
Where do you get the high full primer? What brand did you get? Seems to work quite well.
Where did you find a booth to 2 pac spray the clear coats?
Sent from my GT-P1000 using Tapatalk
Jamie hows your tdi goingg? Your build thread is slowing downn a bit..are you still planning on getting rid of it?
08 VW MKV Golf TDI - reflex silver | pioneer nav unit | 18" black Apec racing rims | DSG | custom TurboBack exhaust | reset springs | gti steering wheel | R-Line tail lights | angel eye/projector headlamps | gti front | R32 rear | red engine cover | opticoat |
