Page 7 of 14 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 133
Thread: lowtdi's mk5 build
  1. #61
    Jan 2008
    Sunshine Coast
    A dump pipe will give you ten times greater gains than any intake, good idea! Nice Provent install, is that Western Filters universal kit? It will take time for oil to collect, but don't wish for it!!
  2. #62
    Jul 2011
    NEWCASTLE NSW
    i think it'd be a fun mod, not that id be doing it myself, mores fun in that people will be like wtf is that?!
    i just bought the prevent unit, and 2 metres of silicone oil return hose off ebay. the hose is a bit thick i might try and fid something a bit slimmer as i wouldn't mind getting the engine cover back on.
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
  3. #63
    Jul 2011
    NEWCASTLE NSW
    relocated the prevent to under the air intake near the battery and firewall, nice and hidden, and managed to get the engine cover back on.
    anyway i found out my idle problem.
    have borrowed jarred ( jazd) ross tech cable, and i have fault 19559 which is faulty intake manifold flap. I'm going to give it a good clean today and check the wiring, otherwise replace it.
    makes sense that it might be stuck open, thus giving me high revs at idle. as its meant to shut at idle.
    will let you guys know, and update pics of where my prevent is now!
    ---------- Post added at 12:37 PM ---------- Previous post was at 09:00 AM ----------
    nope, intake manifold flap is rooted
    500+ for a new one
  4. #64
    Nov 2007
    Quote Originally Posted by lowtdi View Post
    I was under the impression silicone hoses were bad for oil vapour?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  5. #65
    Jul 2011
    NEWCASTLE NSW
    what type of hoses are people using then? silicone is working fine for me..
  6. #66
    Gosford Central Coast NSW
    Quote Originally Posted by poyta View Post
    silicone is about as good as you'll find practically.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #67
    Jul 2011
    NEWCASTLE NSW
    managed to get the intake manifold flap for 320, will fit it myself and clear the codes with vagcom, courtesy of jazz
  8. #68
    Nov 2007
    Silicone is fine but they need to be Fluorosil lined to be resistant to oil. If its not lined then I'm pretty sure that your silicone hoses will bleed out the oil or will break down inside. This will happen over time as it fills up with oil. You haven't had them installed long enough to see the effects. If you say they sold you ones specific for oil use then it should be ok.
  9. #69
    Jul 2011
    NEWCASTLE NSW
    Hose
    The hose is like 20 dollar a metre oil return hose from a fluids place. I'll just check it periodically to see how it's going. I'd say it's oil resistant considering it's used for oil pumPs etc usually. And it's mounted against the firewall now so it's a bit of a pito to get to.
  10. #70
    Jul 2011
    NEWCASTLE NSW
    allright, provent is off. the hose was sh*thouse and leaking and creasing. ended up forming a fold and sealing the pipe, then fuel consumption jumped up to about 7-8l/100 . I've pulled it off for now and i bought some new pipe today but its way too thick. waste of $40 bucks. so I'm really at a loss for what to use. i might wait until i get a new intake until i refit the provent.
    does anyone know where to get some decent hose that won't seep oil, so i can refit my provent
