Page 5 of 14 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 133
Thread: lowtdi's mk5 build
  1. #41
    Ok thanks for the feedback. No doubt the replacement injectors cost a pretty penny too? Does it kill all 4 or does it just affect one or two of them?
    Quote Originally Posted by benough View Post
    I've had a GT Sport TDI for 3.5 years and other than the dreaded injector issue affecting that motor only, mine's been bullet proof.
    I've put 120k on mine and it's as good as the day I got it.
  2. #42
    Forgive my ignorance on this matter but im trying to make sense of the VW diesel engine range.
    TDI 1.9 litre
    Power (kw) ?
    Torque ?
    TDI 2.0 litre single cam 8 valve
    Power (kw) 103
    Torque 320nm
    TDI 2.0 litre "GT" twin cam 16 valve
    Power (kw) 125
    Torque 350nm
    Can someone help me out with the specs for the 1.9?
    Also, how is the diesel with the 6 speed manual?
  3. #43
    Oct 2010
    All have to be replaced at once as well as the wiring loom. From most accounts VW will cover the entire cost or most of it even when the car is out of warranty.
    eg. from today:
    http://www.vwwatercooled.org.au/foru...tml#post732199
    TDI 1.9 litre
    Power (kw) ?
    Torque ?
    Power (kw) 103
    Torque 320nm
    Power (kw) 125
    Torque 350nm
    Are you looking only at the Mk5? I thought the 1.9 was SOHC 8v and the 2.0 103kW was DOHC 16v.
    Golf GT Sport TDI
  4. #44
    Yes im looking at Mk5. I think the 1.9litre is the same 77kw/250nm as used in the Polo. If so ill pass on that motor and aim for the 2.0litre with 103kw (GT's are out of my price range unfortunately).
    Quote Originally Posted by jazd View Post
    eg. from today:
  5. #45
    And to my knowledge, the 103kw is a single cam 8 valve while the 125kw version is the more advanced twin cam motor.
  6. #46
    Adelaide hills, SA
    To my knowledge the 103kWTDI is DOHC 16V engine.
    1.9TDI is 8V SOHC
    The 125kW version of 2.0L TDI has some internal changes to handle the extra power and piezo injectors (PD).
  7. #47
    If you want more power (and torque!) out of the 103 kw engine there are plenty of options available. A simple tune takes the the 103 kw up around the power and torque figures of the 125 kw engine.
    I preferred the dsg when I was test driving both. Lots of gear changes needed if you go manual!
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
  8. #48
    Apr 2008
    But if you want the car for longer commutes, go manual.
    I find it better b/c you can pick your shift points better and hold it in gear for the torque/power band.
    Also less to go wrong or break.
    A Dieselgeek short shifter makes light work on the gearbox as well.
  9. #49
    You can do that with dsg in manual mode...
    True that.
  10. #50
    Apr 2008
    Quote Originally Posted by stickshift3000 View Post
    Yeah but it's not as cool and shifting with your hand.
