Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 91
Thread: Liqui Moly DPF cleaner
  1. #41
    Thanks for the info guys much appreciated .
  2. #42
    Feb 2014
    Central Vic
    Quote Originally Posted by Amalgam View Post
    Penrite DPF cleaner contain Cerium
    What is Bi-Metallic........ two active catalysts –
    http://www.penriteoil.com.au/tech_pd...rch%202014.pdf
    as you quoted
  3. #43
    Feb 2014
    Central Vic
    Hmm.....Penrite enviro+ DPF cleaner.
    Whats a good price and where ?.
  4. #44
    Aug 2012
    Perth WA
    Quote Originally Posted by Ryeman View Post
    I usually wait for when Repco or Supercheap have a % off sale and stock up.
    I tend to use it when I holiday allowing passive regen from high EGT and Cerium to do their magic synergistically.
  5. #45
    Feb 2014
    Central Vic
    Our approaching trans continental trip is the perfect opportunity to give it a dose.
  6. #46
    Mar 2016
    Northern Rivers NSW Australia
    Yes I have just used the Liqui Molly DPF cleaner. My DPF was 101% blocked at 84,500klm. Purchased it from Autobarn for $760.00. Had a pro put it through the filter without removing it. After treatment the computer read 30% blocked and then the Regeneration was performed and the computer indicated 0% blockage. After a 1000klm trip over Easter all seems really good. Will let you know if there is any change. I have kept the kit and can now do it myself for $100.00 Hope this helps.
  7. #47
    Aug 2012
    Perth WA
    Quote Originally Posted by I'll See T5 Campervan View Post
    84500km doesn't seen like a lot of kms
    What sort of driving style and brand of diesel do you use??
  8. #48
    Dec 2008
    Sydney/Canberra
    I think I read in another thread that it's an ex-Ambo.
    Depending on where it was based, it may have just spent a lot of time idling away, with only light work.
  9. #49
    Jan 2008
    Sunshine Coast
    $760??
    You can get Western Filter to bake and basically re-manufacture your DPF core for less than that....
    Plus that sort of $$ will buy a low km DPF out of Europe.
    Hell, cut the end off and go to town with a pressure washer!
  10. #50
    Feb 2014
    Central Vic
    Quote Originally Posted by Greg Roles View Post
    $760??
    That's alright for the young and equiped.......bit late for this baby boomer though.
