Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 91
Thread: Liqui Moly DPF cleaner
  1. #81
    Feb 2014
    Central Vic
    Quote Originally Posted by stevan View Post
    A word of warning should you use the intake cleaner, do be careful as the tube attachment tends to leak where it fits into the press button at the top of the can.I discovered as I was spaying into the intake it dripped onto my grill...It eats plastic! Not so pretty...Seems to do a good cleaning job though.
    I thought it was a safe product for plastic induction manifolds.
  2. #82
    Jan 2008
    Sunshine Coast
    What is being discussed here is a direct to DPF fluid. Then you have fuel additives, then you have intake cleaners. People are confusing them.
    This 2 stage DPF cleaner is designed to go directly into the metal DPF can, not through the fuel, like a petrol additive ( which would not get your intake anyway - direct injection ). The only intake cleaners are the seafoam types, and the diesel specific one is fine for plastic.
  3. #83
    Feb 2014
    Central Vic
    Greg, isn't this a retail product, and as such, how would the average Joe get it directly to the can?.
  4. #84
    Jan 2008
    Sunshine Coast
    Yep, ideally you want the super expensive wand and air setup, but so too just the fluids injected under pressure would work - via the top O2 sensor port, not a simple task, but easier than cutting it open and washing it out!
    Any mechanic could handle it for you I reckon.
  5. #85
    NSW
    Yes it was the intake cleaner that ate my grill! Not DPF cleaner...
  6. #86
    Feb 2014
    Central Vic
    So how does it not eat plastic induction manifolds?.
  7. #87
    Jan 2008
    Sunshine Coast
    Inlets are nylon based, bumpers are plastic based.
  8. #88
    Feb 2014
    Central Vic
    Quote Originally Posted by Greg Roles View Post
    Ah
    its all plastic to me ))
  9. #89
    Feb 2014
    Central Vic
    Adelaide hills, SA
    I've never had any issue with the MAFF cleaners currently in the market.
