Thanks for the info guys much appreciated .
Hmm.....Penrite enviro+ DPF cleaner.
Whats a good price and where ?.
Yes I have just used the Liqui Molly DPF cleaner. My DPF was 101% blocked at 84,500klm. Purchased it from Autobarn for $760.00. Had a pro put it through the filter without removing it. After treatment the computer read 30% blocked and then the Regeneration was performed and the computer indicated 0% blockage. After a 1000klm trip over Easter all seems really good. Will let you know if there is any change. I have kept the kit and can now do it myself for $100.00 Hope this helps.
I think I read in another thread that it's an ex-Ambo.
Depending on where it was based, it may have just spent a lot of time idling away, with only light work.
$760??
You can get Western Filter to bake and basically re-manufacture your DPF core for less than that....
Plus that sort of $$ will buy a low km DPF out of Europe.
Hell, cut the end off and go to town with a pressure washer!
