The light still comes up because I always interupt the process.
Had heaps of DPF issue all the way to 30k km due to short trips and interupted regens. After using the BP Ultimate diesel plus Cleendiesel and DPf service additive from cleenergy.com.au I hardly have any issues even interupted regens.
Did you get their Diesel service pack? It seems pretty good value.
So did you need to use all of the DPF service or half of it to clear out your DPF to the point where your car ran properly?
Resident grumpy old fart
Works very well. We have cleaned plenty of DPF's successfully. No need to pull the DPF out (except on an E70 X5).
Just curious if anyone has found this stuff at any of the retailers? My car gets a bit of peak hour work so feel it might be a good preventative measure before i even get the warning lights.
Just to to cleenergy.com.au they deliver
