Results 1 to 10 of 14
Thread: letter from the epa re: SMOKE!
    Apr 2006
    Melbourne, Victoria
    Hello all,
    yes, I've had a complaint about the soot and have to concede that the little beast blows more smoke than a semi on a hill start. It has new injectors and has great compression, doesnt burn oil and timing is correct. I suspect the max fuel "smoke" screw or that the pump might be worn/stuffed. I havent played with the smoke screw, has anyone had any experience or advice?
    Cheers,
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Jun 2007
    Eastern Suburbs Melbourne
    Sorry, no advice from me at all. I would suspect fuel screw for starters.
    Did the EPA say anything in regards to fine or anything?
    i like volkswagens
    Adelaide hills, SA
    Quote Originally Posted by hiho View Post
    Hello all,
    Cheers,
    Matt
    I take it as you already checked air filter, did you? Just make sure it's clean first.
    Than check the injectors, pull them out and have them adjusted and spray pattern checked, replace them if needed.
    Jun 2007
    He said the injectors were new....? if they're new, they shouldn't need to be checked no..?
    i like volkswagens
    Canberra
    "Shouldn't need to be checked" is true, but depending on the quality assurance of the manufacturer "new" (or reconditioned) doesn't necessarily mean they are perfectly OK as supplied. Always good to have them checked before installation.
    I'd be getting a decent mechanic with diesel experience to check it out - you will probably get better fuel economy after the problem is fixed as well (soot is just unburnt diesel fuel).
    Oct 2009
    Williamstown, SA & Broome WA
    Air Cleaner first. Just remove it temporarily. Take it for a run. Any smoke? Don't forget to put it back in!!!!! Then as a few said, adjust the fuel screw. Very easy to do, there will be a locking wire on it, with a little lead/alli button sized factory stamp on it (that is unless someone has been in there already)!! It's usually a 12mm or 13mm spanner and flat screwdriver.To shut it down (less smoke) you'll meed to wind it out, half a turn at a time (go till you have less smoke and still have usable power). You will know you have gone the right way as the idle speed will drop to. You will need to adjust this on the throttle idle stop (10mm spanner and flat stumpy screwdriver) which is found 'behind' the pump body. Enjoy!
    Jan 2008
    Sunshine Coast
    Don't be overly concerened, this is simply the smokey exhaust hotline you can call, and if a car is reported a few times within a year or so period, they ask you to get it inspected. Otherwise it's just a scare tactic.
    I use it on any cars I see blowing ludicrous smoke while driving, where the rings etc are obviously shot, such as pretty much any old Excel.
    Gosford Central Coast NSW
    Quote Originally Posted by cogdoc View Post
    i cant say i dissagree with your sentiments, but isnt that feeding the beurocracy? (sorry about spelling..)
    i've never had a letter.... luck probly
    anyway hiho, wind the fuel screw out half a turn. that'll fix it
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2008
    Sunshine Coast
    Dude there's smoke / soot, and then there's an obvious polluter whos car is pouring out oil smoke all the time and needs some motivation to get the engine overhauled. You know what sort of cars I mean, we've all seen them, and it's the extremes I have a problem with.
    It's only a letter, as if most people do anything but throw it in the bin! At least hiho is enough of an enthusiast to do something about it, more credit to him for that!
    no no i mean i agree with what your saying about smokey old magna's etc.... oil smoke is yuk...
    '99 A4 Quattro 1.8T
