Page 24 of 34 FirstFirst ... 142223242526 ... LastLast
Results 231 to 240 of 336
Thread: Let the tinkering get serious!!....
  1. #231
    Apr 2008
    Sweet!
    What does it mean? haha
  2. #232
    Jan 2008
    Sunshine Coast
    Sorry, that's a Snow water meth controller injecting. Finally!
  3. #233
    Gosford Central Coast NSW
    Greg, glad to see you finally injecting some meth.....anol
    No surprise that your getting a smoother throttle response.
    When you refer to run-away - are you just referring to the turbo leaking oil into the inlet if it decides to go belly up? Only reason I ask is that since you now have no crankcase breather gasses going in pre turbo.... theres nothing in the air to burn anymore.. (well, apart from methanol).
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #234
    Jan 2008
    Sunshine Coast
    I can't help but wonder what would happen if you blew a turbo seal, all that lovely hot oil to run to redline on.
    I really wanted to have it for shutdown "anti shudder", but the shutdown without any flap is hardly any worse, and the drive home I had in start stop peak hour traffic was just wonderful. Even creeping along on off in first is just SO dramatically smooth now, feels like a NA petrol car off boost down low, and the boost pickup is a lot more rapid. That stock EGR/Flap is causing ALL the hesitation, pauses and rough running, and I'm loving my car all over again.
    I have to come clean and admit I'm only injecting distilled H2O for now, as I want to set the system up right, check for leaks, and I'm waiting till pay week next week for a decent volume of Methanol. I did check my inlet on getting home tonight, and the QTP flap and black manifold were warm at best, MUCH better without the hot EGR entering, and with the water spray happening, it's a lot cooler in there.
    Does feel good to be finally making some serious progress after three years of a lot of pondering and minor mods. Having no warranty anymore is a liberating thing too. Scary, but refreshing.
  5. #235
    Jun 2006
    Orange NSW
    Nice work, Greg. Lovin' it!
  6. #236
    Jan 2008
    Sunshine Coast
    It's been interesting driving the car for 2 weeks now.
    1. It's dramatically smoother, more eager, and feels like it's had a new lease of life.
    2. It has as yet to do another regen! In theory taking the EGR out shoukd raise EGT's and in return drop soot production, plus help the DPF run hotter, so it should passivley regen better. I'd have to say that in it's current odd state of quite frequent regens after the pressure sensor replacement, it;s odd to have gone this long without a regen. I'm putting in on Vag Com for the drive home just to check soot levels.
    3. I've got a tiny leak through one side of the QTP flap, so will have to sort that out before I go methanol.
    4. Injecting just water my manifold on the engine is cool to the touch after running the car. Amazing.
    Heavily into the exhaust pipe now.....
  7. #237
    Jan 2008
    Sunshine Coast
    Final stages coming together.....3" resonated mid pipe from 42DD today....to add to a 2.5" cat back "just lying around"... : )
    Also fitted an electronic QTP flap controller, so have much better control of the intake flap for regens, and emergency shutdown.
    Hope to never use that!
  8. #238
    looks like a nice System Greg! Really interested to see the results
  9. #239
    Jan 2008
    Sunshine Coast
    Just to let everyone know, it's impossible to complete a standard DPF regen without the EGR mechanism hooked up to the loom, albeit hanging in the breeze. Anyone considering an Allards EGR delete, if you have a DPF, it's going to cripple the regen cycle, and while I had mine unhooked the DPF load got up to a all time high of 60% and I had to hook the EGR mechanism back up ( only to the loom ) to complete a regen with my QTP flap. The DPF light came up at this level of loading ( first time for that one ) and the engine light is on due to the low EGR flow error.
    The electronic controller has been impossible to calibrate, so I have had to go back to a simple switch, but it works fine for regens. Hope to get the QTP controller to work so I can close it a bit more accurately than just counting 2 seconds and hoping it;s about half way ( takes 5 seconds to fully close ).
  10. #240
    Nov 2007
    They don't make it easy do they? Best to just rid of the damn DPF then.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
