Thing is Ayden, I was basically seeing this:
Whereas in the stock green boost line, you could feel it spike to the normal 22 and then settle down to 17psi or so and pull through to 4000rpm, in the red overboost state it was rapidly hitting 25psi, stuttering terribly then topping out around 30psi all before 2000rpm. There was just no power to be had in this range either, it was obvious the fueling was out. I didn't want to get into it much, as this was most likely surge territory, and I didn't want to pop the turbo. You had to creep around till you passed the boost spike, and even after say 2500rpm, there just wasn't the usual strong torque or psi, something was obviously way wrong. It was horrible to drive!!
