Thanks to a rainy weekend, got into the engine bay once again. Tided up my new battery wiring, and put all my electronics kits into one big box which will be far more weather proof. Nearly at the stage of having it all running!
Spent the rest of the weekend getting the intercooler pipework from the turbo to IC completed, and bolted into the factory mounts. Took a lot of messing around to keep the joins minimal, in line, and not hitting anything. Also made several mockups and sacrificed some pipes to avoid 90 degree elbows, and keep it all as short as possible. It's a fair bit shorter than stock, with much better bends, according to theory. Ignore the amount of blue on the pipes, there's some there to act as potential rub guards where it comes close to the gearbox. All joins bead rolled and siliconed, just to be sure. Test drive later today!
![](http://www.vwwatercooled.com.au/forums/images/imported/2010/10/DSCF3366-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2010/10/DSCF3367-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2010/10/DSCF3368-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2010/10/DSCF3371-1.jpg)
